Can of worms? rust in footwells!
Posted: Thu Feb 16, 2006 4:58 pm
by oguz327
Posted: Thu Feb 16, 2006 5:13 pm
by Kos
i have seen a lot worse!!!
Posted: Thu Feb 16, 2006 5:15 pm
by jonb
kos
you should know plenty about rust.
oz. looks like someones had a go at "rebuilding" that drivers jacking point already.
Posted: Thu Feb 16, 2006 5:33 pm
by oguz327
Are we talking big money to put right then guys?
I asume those corners are gonna be difficult to weld
Posted: Thu Feb 16, 2006 5:34 pm
by dazleeds
very interested in whats said here lol
as i'll be doing the same next week
hope i dnt find too much rust
Posted: Thu Feb 16, 2006 5:37 pm
by Kos
jonb wrote:kos
yes i though it was a worth while mod to the M3 if that what you are on about. it cost me nothing to do and saved a few kg's, didnt see the point in spending Ԛ£1000 in carbon
Re: Can of worm? rust?
Posted: Thu Feb 16, 2006 7:25 pm
by bullitt
oguz3001 wrote:Well finally got my carpet out of my tech 1 after stripping the interior out to investigate leeks/wet carpet.
Good new is after romoving rear quarter card i can see that both rear inerer arches have been replaced probaly not long before i brought the car in 2003.
Bad new is some real bad rust around where the accelerator pedal meets the pedal floor mount
Passenger side was not too bad but may still need a bit of attention.
Any opinions or advise welcome
1st things 1st Leak Test??
Use a garden hose or watering can to imitate rain fall a search for leaks, scuttle panel, bulkhead, screen seal, door seals & door membrain..
Try to make holes in the rust with a screwdriver..
If no holes appear and the metal is strong grind out a much as possible and treat it with a Rust Inhibitor then prime with an anti rust primer..
Holes!! The only way to tackle rust is to cut it out, i have replaced both these places on a mates sport by cutting out the section then fabricating and welding in new metal..
If you have a compressor, airsaw, mig welder & some common sense go 4it..
Posted: Thu Feb 16, 2006 8:09 pm
by oguz327
Cheer bullit, ill try that for the leaks.
I think some of it will grind out and can be rust treated, but the bit by the accelerator pedal deffo has a small hole.
Deffo a 3rd party job just dont have the kit for this kind of work
Posted: Thu Feb 16, 2006 9:47 pm
by oguz327
Has anyone had this type of problem and got it welded up?
Just wondering roughly how much this is gonna cost to put right
