Radiator Blind
Posted: Fri Feb 03, 2006 6:13 pm
by martinclan
My 318is takes ages to warm up in this weather. In fact it doesn't on my short (<7 miles) journey to work. Result - appaling fuel consumption. So does anyone know if there was or is a radiator blind for the E30.
Yeah - I know I can use a plastic bin liner but it doesn't look very cool
Robin
Posted: Fri Feb 03, 2006 6:45 pm
by Grantley
I would have thought it would warm up on a journey of that length, maybe the stat is stuck open causing it to stay cold for so long !
Posted: Fri Feb 03, 2006 6:49 pm
by eko
Posted: Fri Feb 03, 2006 6:13 pm Post subject: Radiator Blind
Same problem as mine.
I am going to change the stat because on checking today i found everything is getting warm apart from the one hose going to the stat housing.
Check yours,could be the same problem.
Thermostat
Posted: Fri Feb 03, 2006 6:53 pm
by martinclan
I am pretty sure that the thermostat is fine as it gets up to normal temperature on a slightly longer trip and is stable. If the thermostat were stuck open it would NEVER get up to temperature - mine just takes longer than it should....
Posted: Fri Feb 03, 2006 6:56 pm
by eko
mine also gets upto temp(eventually) but heater on tickover is crap,give it a few revs and it goes warm for a minute then goes shite again!
Still worth you checking that hose against the others when its warm to see if it is hot/cold.
Posted: Fri Feb 03, 2006 10:52 pm
by E30Mark
My iS only takes a few minutes to warm up, approx 3 miles and it's blowing nice warm air on my feet. Check your thermostat.....
How old is your water pump? the impeller could be loose.
Posted: Fri Feb 03, 2006 10:58 pm
by Widge
If the thermostat is broken it would warm up and would hold a stable temprature as the fan would regulate the temp. It would just take ages to get up to temp.
Posted: Fri Feb 03, 2006 11:08 pm
by dizz
MY 318i also takes ages to warm up in this weather, i changed the stat and that made no difference.
So i cut a strip of clear acitate (plastic) to go from head light to head light, (the same hight as the head light) and held it on with clear cable ties, and now i get hot air from the heater in about 2 miles and it sits just under half on the gauge on longer trips.
As long as i keep it clean its almost invisible as you can see the grill behind it.
