What to do with my e30
Posted: Thu Nov 29, 2018 3:45 pm
Hi, I’m new on this forum,
Recently I bought a bmw e30 318i which had an m52 non vanos swap. Not long after owning it started so show some signs of what I believe is the head gasket going, it all started with the engine beginning to misfire and the first thing I did was check the spark plugs, I came to find that 3 of them had signs of oil on them. I quickly replaced these which seemed to solve the issue for now, a bit of a short term fix. Not long after that I noticed the car began to run quite hot and that’s when I stopped driving the car. I pulled off the oil cap to look inside and It straight away smelt quite burned but it looked like it had been changed recently. I then decided to empty the oil out and have a look and when I did this there were creamy sort of lumps inside the oil.
So I believe I was led on by the previous owner who knew something was up. I’m a stuck on what to do next, I have thought about just taking the engine out and having it skimmed to put a new gasket on there and solve some small oil leaks while I was at it, but as I started doing this I realise how bad of a job the swap had been done, there are random wires everywhere, some that have been tapped into, a lot of bolts seem to be missing and the person who did the swap has done some awful welds on part of the exhaust. This is making me consider just getting a completely different engine and starting fresh with the car so I know what is what, should I go m52 again, or get an m20 or shall I go m50 for now and then turbo later on in the future???? Any thoughts from you lovely people
