anyone use camber plates on non coilover set up ?
Posted: Wed May 10, 2017 9:45 am
by puregttipower
hi guys is it possible to use camber plates on lowering shocks and springs on e30 cabby? i read on one ebay advert guy put you need coilovers?
any help will be great
thanks
Re: anyone use camber plates on non coilover set up ?
Posted: Wed May 10, 2017 7:32 pm
by steve_k
i've got a set of eibach/spc camber adjustable top mounts on my sport with a shock/spring set up, never had any problems in the 10yr's they've been on the car.
Posted: Wed May 10, 2017 8:16 pm
by puregttipower
thanks for info will something like below be ok to use?
http://www.ebay.co.uk/itm/Camber-Plates ... 2649538356
Posted: Wed May 10, 2017 8:18 pm
by ross_jsy
Why do you want to adjust the camber/castor on a cab :?
Posted: Wed May 10, 2017 8:21 pm
by steve_k
they look like they would do the job,
at that price range just be careful with the bearings as they might need greasing once a year at best or replacing at worst.
these are the one's i've got
http://www.ca-automotive.co.uk/variants ... 3NA==.html
but as you can see not cheap lol,
the ones you've posted should be fine though, just be aware that if you go for full neg camber the top hat on the shock will rub on the inside of the strut tower.
Posted: Wed May 10, 2017 8:45 pm
by puregttipower
thanks for info steve, ... rossy im going 9.5 on the front thats why :)
