Bonnet insulation REMOVAL - best way?
Posted: Thu Nov 17, 2016 8:08 pm
by gillsl500
Hey chaps,
I've finally started my e30 restoration
So first question is, what's the easiest way to remove the insulation under the hood, especially that sticky residue that's left behind as it's going to be painted.
the problem is more so the sticky glue that left behind. So any ideas are greatly welcomed:-)
Re: Bonnet insulation REMOVAL - best way?
Posted: Thu Nov 17, 2016 8:49 pm
by DHFiS
I used a hot air gun on the lowest setting and a plastic scraper. Once it gets a bit warm you can push the glue into a lump then pull it off.
Posted: Thu Nov 17, 2016 10:42 pm
by andysheep
Paint thinners to finish off the resdue
Posted: Thu Nov 17, 2016 10:53 pm
by gillsl500
FairPlay ladsa˜€a‘a
Posted: Thu Nov 17, 2016 11:46 pm
by andysheep
Crappy job, iv done twice now,good luck mate,but while doing it with the bonnet upside down ,dont dent it,i did on my cabby,very easy to do
Posted: Fri Nov 18, 2016 11:36 am
by Gert_8
I think Barry suggest the best removal item was toyota's brake fluid to remove the gunk..
Posted: Fri Nov 18, 2016 9:17 pm
by BenHar
Gert_8 wrote:I think Barry suggest the best removal item was toyota's brake fluid to remove the gunk..
Toyota brake cleaner not fluid!
Brake fluid will strip the paint.
Ben
Posted: Fri Nov 18, 2016 9:23 pm
by Gert_8
Shit! Thanks Ben.
Posted: Fri Nov 18, 2016 11:50 pm
by gillsl500
Thanks again guys, what about sand blasting it??
Posted: Sat Nov 19, 2016 7:14 am
by Gert_8
That isn't going to help the paint, you may as well use the fluid.
Brake cleaner, as corrected above, is the best solution.
Posted: Fri Nov 25, 2016 4:15 pm
by ianev
where does one acquire the bonnet insulation please?
Posted: Fri Nov 25, 2016 4:21 pm
by Gert_8
Cotswolds on here..!
Posted: Fri Nov 25, 2016 4:49 pm
by ianev
I thank you, Sir!
Posted: Sat Nov 26, 2016 11:09 am
by retroboyo
I used a fag lighter
Posted: Mon Nov 28, 2016 12:39 pm
by ianev
anyone have the part number for the insulation please?
Posted: Mon Nov 28, 2016 12:42 pm
by Gert_8
51488103798.
Bonnet insulation.
Posted: Tue Dec 06, 2016 7:09 pm
by peterjcollins
I pulled mine off and then used petrol painting it on with a paint brush.
Obviously must be done outside due to fumes and risk.Use good quality PPE
Posted: Tue Dec 13, 2016 11:08 am
by ianev
Gert_8 wrote:51488103798.
Bonnet insulation.
Thanks buddy!
