S50 problems again
Posted: Tue Jul 26, 2016 5:40 pm
by Siggo
Car still cutting out again when driving. Have replaced crank scencer. Maf cleaned the earth wires replaced 6 rubber trumpets.fuel pump ok car even worse than before any idears
Re: S50 problems again
Posted: Tue Jul 26, 2016 8:01 pm
by bigbird76
ECU Dry solder joints?
Posted: Tue Jul 26, 2016 8:14 pm
by Siggo
Will put it on the check list thanks
Posted: Tue Jul 26, 2016 8:19 pm
by maggspower
have you had it plugged in, and the codes read
Posted: Tue Jul 26, 2016 8:57 pm
by Siggo
Yep that's why replaced air mass metre and crank scencer
Posted: Tue Jul 26, 2016 9:22 pm
by Siggo
It also idles now at 900 revs. My research still saying crank case sensor
Posted: Tue Jul 26, 2016 9:40 pm
by maxfield
What make crank sensor did you use?
Posted: Tue Jul 26, 2016 10:05 pm
by spook
crank case sensor 150 from the dealers mate :D
Posted: Tue Jul 26, 2016 10:14 pm
by Siggo
Yeah 120 plus vat from bmw.
Posted: Tue Jul 26, 2016 10:26 pm
by spook
Is the crank sensor showing bad on your code reader?
Posted: Tue Jul 26, 2016 10:42 pm
by Siggo
No. Got time of work soon . Taking inlet manifold off check idle valve. pipe work for splits see if that helps
Posted: Wed Jul 27, 2016 6:36 pm
by Siggo
Replacing throttle position senser see if that is the problem
Posted: Wed Aug 03, 2016 8:39 pm
by Siggo
Replaced throttle sencor . Cars running great so far
