Suggestions for E30 M3 coilover suspension
Posted: Sun May 29, 2016 2:50 am
by Akmpower
Hi guys looking for suggestions / recommendations on coilover suspension for my E30 M3.
Many thanks.
Re: Suggestions for E30 M3 coilover suspension
Posted: Sun May 29, 2016 8:53 am
by Brianmoooore
Depends a lot on what the proposed usage of the M3 is.
Posted: Sun May 29, 2016 2:09 pm
by Akmpower
Mainly road use with a odd bit of track use. Something decent and reliable with good adjustments.
Posted: Sun May 29, 2016 2:16 pm
by ross_jsy
What is your budget?
There's a lot to be said for decent non adjustable dampers such as Bilstein B8's. Coil over strut conversions can be welded on to give you height adjustment
Posted: Sun May 29, 2016 3:26 pm
by Akmpower
I don't really have a budget just want the right kit as in ride quality, adjustments etc. Are the coilover kits a direct fit or do they need some playing around?
Posted: Sun May 29, 2016 7:09 pm
by ross_jsy
AST are about as good as you can get within reason (I.e. not £10k racing stuff). £3,250 for their top of the line stuff. On a lower budget, BC's are very good value for money. I've driven a couple of cars with them and can't fault them for the price. My friend has been using them on his daily for a year or 2 with no complaints. Adjustments are basic though.
I do not recommend Gaz Golds. One of my cars came with them and they were sold. Never felt right and other people report similar things. The finish on them is also poor.
All coil overs for e30's need a bit of fiddling. Unlike e36's etc where the hub bolts to the strut, it is welded on an e30 so the strut needs to be cut, the outer sleeve of the coil over welded to it and then the shock screws in.
I use Billie's on my daily with threaded bodies for the spring adjustment. Same process as converting a normal e30 strut to coil overs
Posted: Sun May 29, 2016 8:22 pm
by ajay
Re:
Posted: Mon May 30, 2016 2:59 am
by Akmpower
Many thanks for the input soo far guys, any deals going on the AST suspension you know of or any suppliers you can point me in the direction of would be much appreciated.
Re:
Posted: Mon May 30, 2016 9:24 am
by ross_jsy
Re:
Posted: Mon May 30, 2016 1:36 pm
by Akmpower
Thank you ross_jsy for your input. Ajay which model in their range have you gone for?
Posted: Mon May 30, 2016 8:06 pm
by ajay
I bought the 5100 fronts & getting 5300 rears. I can't have a canister under the bonnet (bit too race car for me), but can hide them on the rears, i also have it on good authority that the 5100, will exceed my expectations.
