Short Shift Advice
Posted: Tue Sep 22, 2015 10:38 am
by LondonTom
Hi Guys,
I'm after a bit of advice for which shifter to go with on my track car.
I was hoping to find an aftermarket shifter but not worth spending the money as I'm a shite driver.
So I have narrowed it down to either the Z3 2.8, Z3M or Z4 3.0. If anyone has used the above shifters and could give me some feedback, I'd really appreciate it.
Might also be worth noting I will be using quite a tall gear knob.
Tom
Re: Short Shift Advice
Posted: Tue Sep 22, 2015 10:44 am
by bosers
I got a twenty quid one off fleabay and it works fine. :)
Posted: Tue Sep 22, 2015 12:22 pm
by LondonTom
bosers wrote:I got a twenty quid one off fleabay and it works fine. :)
I'd rather go with a bmw part then one of those, I know a few people use them though.
Posted: Tue Sep 22, 2015 8:01 pm
by hillbilly30
Be carful to read the description of the cheap ones as I think some of them are quite extreme, one was advertised as shortening the lever 4" That seemed a lot!
Posted: Tue Sep 22, 2015 8:21 pm
by KW355
Me too :D
Posted: Tue Sep 22, 2015 8:22 pm
by Acaciastrain360
Me too :D
Me three :D
Posted: Wed Sep 23, 2015 12:26 am
by LondonTom
Thanks but re the eBay ones I wouldn't fit one to my car as I would rather go for a branded part.
Posted: Wed Sep 23, 2015 2:19 am
by motormanmick
Genuine Z3 1.9 short shifter, not sure how short, but may be what you are looking for
http://store.garagistic.com/e30-perform ... rts?page=4
Posted: Wed Sep 23, 2015 8:41 am
by LondonTom
motormanmick wrote:Genuine Z3 1.9 short shifter, not sure how short, but may be what you are looking for
Thanks mate - the wiki on here is really useful and give the part numbers and prices (not sure how recent though).
Think I'm going to go for the Z3m.
Posted: Wed Sep 23, 2015 9:26 am
by DanThe
Beware as depending on what gearbox/prop combo you have you may not have enough room for a very short throw lever, I drove an M20 with a Z4 3.0 which is slightly longer throw than the Z3 M and it was awful, the box just isn't up to the precise gear change thats needed to engage it with such a short throw
Posted: Wed Sep 23, 2015 11:36 am
by LondonTom
DanThe wrote:Beware as depending on what gearbox/prop combo you have you may not have enough room for a very short throw lever, I drove an M20 with a Z4 3.0 which is slightly longer throw than the Z3 M and it was awful, the box just isn't up to the precise gear change thats needed to engage it with such a short throw
Thanks for the feedback Dan - I was about to call the dealers.
It's going onto a getrag 260 or 265 (whatever came in a 325i sport) - what would you suggest, the 1.9 or 2.8?
Posted: Wed Sep 23, 2015 1:06 pm
by rotta
ive just done z3 one with related parts its night and day compared to the original cant recommend it enough,
Posted: Wed Sep 23, 2015 1:20 pm
by LondonTom
rotta wrote:ive just done z3 one with related parts its night and day compared to the original cant recommend it enough,
Thanks Rotta - the 1.9 one did you use?
Posted: Wed Sep 23, 2015 2:26 pm
by DanThe
Yep, you don't need anything more than the Z3 1.9 lever on a 325i 8)
Posted: Wed Sep 23, 2015 2:48 pm
by LondonTom
DanThe wrote:Yep, you don't need anything more than the Z3 1.9 lever on a 325i 8)
Thanks Dan - there's a fair bit of play in the lever so will replace the bush too.
Cheers guys.
Tom
Posted: Wed Sep 23, 2015 9:14 pm
by rotta
i did indeed :)
Posted: Sat Sep 26, 2015 8:19 pm
by LondonTom
Going to do this tomorrow - just a quick question - how much do the selector rod need to be bent / modified?
The gearbox is getrag 260/5.
Tom
Posted: Sun Sep 27, 2015 10:53 am
by LondonTom
Anyone?
Posted: Sun Sep 27, 2015 11:08 am
by Cloggy Saint
I used the Z3 1.9 shifter and didn't need to bend the selector rod at all.
Posted: Sun Sep 27, 2015 11:10 am
by Brianmoooore
LondonTom wrote:Going to do this tomorrow - just a quick question - how much do the selector rod need to be bent / modified?
Tom
Are you confusing this with fitting a gearbox to an engine that sits at a different angle?
Posted: Sun Sep 27, 2015 11:30 am
by LondonTom
Thanks Guys.
Brian sorry for the confusion but in the wiki it states the selector rod needs bending yet I have read elsewhere and as Cloggy says above it doesn't need bending at all.
Cloggy do you have a vibration damper on your prop?
Posted: Sun Sep 27, 2015 12:03 pm
by Cloggy Saint
No vibration damper on mine.
Posted: Sun Sep 27, 2015 12:19 pm
by Cypriotgeeza
I have a z3 1.9 on my M30 and what a difference it made!
Feels tight without being too short..genuinely feels like that's how it was always supposed to be!
I wouldn't want to go any shorter than that! :thumb:
Posted: Sun Sep 27, 2015 2:39 pm
by LondonTom
Cheers again lads - all done.
