Bumper vents
BROOMY
busy saving Clifford
Post Mon May 18, 2015 9:05 pm
Hello.
Uno the bumper vents that go into the car.
Is there a cover I can get for them?
The car keeps leaking through it I cleaned it all out but it still comes.
Although it is sitting there unused, but this shouldn't still be happening.
I left it for about a week, I looked today there was like an inch water in there, so I done the usual and drilled a tiny hole in it.
But there must be some kinda fix.
Post Mon May 18, 2015 9:09 pm
No sealing the vents to cover available, and no cover needed. There should be a thin rubber gasket sealing each vent to the body, and if these are missing, water will come in.
BROOMY
Post Mon May 18, 2015 10:27 pm
It must be something else, these have never been removed.
Was fine before, only now it's happened, like the last day but tomorrow we'll find out.
Post Mon May 18, 2015 10:42 pm
Gaskets have been known to break and fall off without the vent ever having been removed.
Ianb
Post Tue May 19, 2015 9:45 am
It's also worth pulling the boot seal off as the lip it attaches to rusts away unseen and as soon as it does the water running in the gully round the seal just goes into the boot.
Post Tue May 19, 2015 10:26 am
I fully agree that the water is likely to be getting in somewhere else other than the vents, but I answer the question as asked. The OP stated "The car keeps leaking through it" not "Could the car be leaking through it?"
Under the boot seal is very likely, or it could simply be coming over the seal if the car is parked at all facing down hill, and the boot hinges and catch aren't adjusted properly.
Post Tue May 19, 2015 12:10 pm
BROOMY wrote:It must be something else, these have never been removed.
if your car has a sunroof the rear of the cassette drains to these vents just check the pipes are firmly in place !
Mitchen
Post Tue May 19, 2015 12:14 pm
I also have a similar problem, and have replaced the vent seals, boot seal, light gaskets, and still it leaks from the DS vent.. I can actually see the water trickle out of it if I direct a pressure washer at the side of the car. The sunroof pipe is also in place and not blocked.
Very annoying, but I'm learning to live with it now :(
1990 320i Coupe SE
viewtopic.php?t=253048
BROOMY
Post Wed May 20, 2015 4:04 pm
Found it to be the light seal.
So while I wait on them parts, I've used silicone around it.
BROOMY
Post Thu May 21, 2015 1:08 pm
Next problem .
Can I test the fuel level sender?
If so how.
Post Thu May 21, 2015 6:44 pm
How many do you have? Varies with tank size.
BROOMY
Post Thu May 21, 2015 8:33 pm
Just 1.
Post Thu May 21, 2015 9:44 pm
Should vary from about 60 ohms when empty to just a few ohms or zero when full.
Difficulty, of course, is filling or emptying the tank while monitoring the fuel level, although it can be done if someone fills the tank slowly at a petrol station, while you monitor a ohmmeter connected to the sensor.
If you are trying to narrow down the cause of a jumping gauge, or similar, it's easier to just connect a resistor of (say) 33 ohms across the sensor's plug terminals, and see if that results in a stable reading of about half.
BROOMY
Post Thu May 21, 2015 10:24 pm
Where do I test ?
What tools will I need?
Post Thu May 21, 2015 11:35 pm
What's the problem you're trying to solve?
BROOMY
Post Fri May 22, 2015 12:19 am
My fuel level at instrument cluster.
I checked the clocks with nothing wrong
All cables fitted securely .
No feedback from the sender.
All it does when the ignition is switched on, lift up a slight bit under the light and stay there,The level will stay there for what seems like forever. At the moment the car is immobile but does what it needs to, so I'm not sure what the fuel levels saying at the moment.but it's below the light which isn't even on the scale.
Everything else works but this... And my alarm :x :x
Post Fri May 22, 2015 10:02 am
diable wrote:Bumper vents are they there just to disipate the air from the boot when you shut the lid?
Fresh air enters an E30 through the grills on the scuttle, and is directed through the footwell, the dash vents, and/or up across the front screen according to the position of the heater sliders. Air passes through the cabin, down across the rear screen, keeping it clear, through the slots at the rear of the parcel shelf, into the boot, down through the boot, keeping it aired, and out through the one way flaps behind the bumper sides.
I'm aware that several of the E30s on here have a few extra entry and exit points, but the above is what BMW intended.
Post Fri May 22, 2015 10:14 am
BROOMY wrote: All cables fitted securely .
Reconnect the plugs on the cluster, access the level sender under the rear seat, and pull the three pin plug off.
Turn on the ignition and use a short piece of wire to link together the brown and brown/grey wires of the plug.
This should make the low fuel light come on.
Remove the wire link and connect it between the brown and brown/green wires instead.
This should make the fuel gauge read full.
If both these things happen, then you level sender is probably faulty.
If NEITHER of these things happen, check for continuity (with a meter) between the brown wire at the plug and a good body earth.
If the light works, but the gauge doesn't, check for continuity between the brown/green wire at the plug and the other end of the same wire at pin 4 of the white plug to the instrument cluster. The easiest way to identify the pin and get at the wire is to cut the little cable tie, and remove the back cover of the plug.
Demlotcrew
Post Fri May 22, 2015 12:43 pm
55l sender is 4-60ohms.
Could be a rotten fuel/speed sensor harness connection if the boot was leaking water. The loom likes to carry water down the fabric tape on the passenger side.......
BROOMY
Post Fri May 22, 2015 4:24 pm
Found it to be the light seal, wrong thread!
Also the leak was on the drivers side.
BROOMY
Post Fri Jun 19, 2015 7:33 pm
Not rained here lately, been pretty sunny too.
So I'm hoping it will start working again.
Do cars over 25 years old actually need a working fuel level ?
Post Fri Jun 19, 2015 10:41 pm
BROOMY wrote:Not rained here lately, been pretty sunny too.
????????????????? Always nice to know when you're about to grind to a halt.
BROOMY
Post Fri Jun 19, 2015 11:30 pm
So I guess they do.
Still never answered the question.
