Brake Upgrade Kit ......
Posted: Fri Dec 05, 2014 12:13 pm
by sindako
Mates , What do think ?
Tomorrow i'll take my conversion plates from the forge ,
i am Upgrading the brakes of my e30 ,
Using E32 Calipers , with Auti TT 312mm x 25mm Rotors .
I Guess Now the Car will Have Better Brakes ,
I've seen E30 with EVO6 calipers and rotors , Subaru Calipers and Rotors , Mercedes w124 brakes and rotors .
But those TT 312mm are damn too good , So I am Goin For it ,
Also It's Amazing i don't have to Miss up with my Hub and the 4x100 diameter , just the conversion plates and Some Rotor Redrilling .
Photos Will Be Posted Soon .
Cheers .
Re: Brake Upgrade Kit ......
Posted: Fri Dec 05, 2014 2:36 pm
by clarko74
I'm just in the process of doing this conversion myself.
With calipers that big you'll probably need a larger master cylinder.
Posted: Fri Dec 05, 2014 9:02 pm
by sindako
I've Read about it somewhere online , And The Conversion didn't include any master cylinder replacement , I'll try it on the OE Master Cylinder , If It's Rubbish i'll get an e36 M3 one or maybe a 7 series one .
I'll hit the Realoem to see what cars had the same cylinder as the E30 , if the 7 series had the same then there'll be no problem .
Posted: Sat Dec 06, 2014 12:02 pm
by Lurch320i
You don't want the same master cylinder as the e30 one
You need a bigger bore one with a larger piston inside
Did I comment on your post on Facebook?
Posted: Sat Dec 06, 2014 12:37 pm
by Ant
7 series E32 master cyl a must have on this I'd suggest
std m/cyl will work but long pedal bigger piston area means the m/cyl needs to displace more fluid per stroke to be an effective upgrade
Posted: Tue Dec 09, 2014 8:22 pm
by satan16v
Do you need to change the brake flexis too?
I'm looking at doing this next year, and have Goodrich hoses at the moment, which I'd like to keep
Its either this or the Porsche 986 set up
But I want to find about the hoses before I commit
Posted: Wed Dec 10, 2014 11:27 pm
by Lurch320i
My braided hoses fit the bigger a calipers just fine :)
Posted: Thu Dec 11, 2014 6:28 pm
by satan16v
Thanks Lurch
Posted: Wed Dec 17, 2014 11:06 pm
by uvels
where can i buy that adopters,can i use e38 Brembo callipers??
Posted: Thu Dec 18, 2014 12:22 am
by satan16v
300mm.de
Posted: Thu Dec 18, 2014 9:47 am
by clarko74
uvels wrote:where can i buy that adopters,can i use e38 Brembo callipers??
The bolt spacing on the E38 brembos is different to the E32 540i ones.
Posted: Thu Dec 18, 2014 10:38 am
by LondonTom
What's the minimum size wheel you can run with this setup?
Posted: Thu Dec 18, 2014 10:41 am
by clarko74
These will work with 16" Hartges but I think that is about the only 16"wheel that will work with this setup.
Posted: Thu Dec 18, 2014 10:48 am
by LondonTom
clarko74 wrote:These will work with 16" Hartges but I think that is about the only 16"wheel that will work with this setup.
Thanks Clarko.
Posted: Thu Dec 18, 2014 1:08 pm
by DanThe
I use a 25mm master cylinder
Some pics of mine here - http://www.e30zone.net/modules.php?name ... &start=200
Posted: Thu Dec 18, 2014 6:19 pm
by Lurch320i
I fitted this setup with my 16" bbs lm reps
No spacer required but I did take a grinder to the caliper slightly to clear the inside of the rim
Posted: Thu Dec 18, 2014 7:11 pm
by DanThe
Whos make of BBS reps are they? Any pics?
Posted: Sun Dec 21, 2014 9:48 am
by satan16v
Will this master cylinder be a straight swap? And improve the pedal feel, when running brembos up front and 540i rears?
http://www.ebay.co.uk/itm/301379572841
Posted: Sun Dec 21, 2014 11:01 am
by Kos
DanThe wrote:Whos make of BBS reps are they? Any pics?
Demlotcrew had a set on his turd
Posted: Sun Dec 21, 2014 3:29 pm
by Lurch320i
My reps are from a company called bmautosport
They look like this
Forgive the state of them, I'm currently in the middle of polishing the lips and painting ther centers
Posted: Sun Dec 21, 2014 11:23 pm
by DanThe
Any manufacturers markings on them?
Posted: Sat Dec 27, 2014 4:18 pm
by Jozi
If you fit a bigger ms because of larger pistons and having to push more fluid does this mean the rears are more likely to lock up quicker because of more fluid being pushed down the lines?
Posted: Sat Dec 27, 2014 4:37 pm
by keri-WMS
Jozi wrote:If you fit a bigger ms because of larger pistons and having to push more fluid does this mean the rears are more likely to lock up quicker because of more fluid being pushed down the lines?
Other way round, the larger m/c area creates lower line pressure for a given pedal force, the clamping force on the pads might be recovered at the front caliper with larger pistons (depending on the actual piston sizes) but the rears don't so you get a bias shift to the front.
Posted: Sat Dec 27, 2014 6:06 pm
by bmw-mad
Do you have pictures?
As I Have the same setup
540 brakes and tt discs
the calliper wont clear my 16" alpina's
Posted: Sat Dec 27, 2014 8:51 pm
by DanThe
He said Hartges winkeye
I have the same problem, want to fit my Alpinas but the fronts need redesigning, new bracket/caliper and smaller disc. Rumour has it you need a 308mm disc to go under the Alpina wheel
Loads of pics in my thread, linked above
