Cleaning the engine bay
Posted: Sun Nov 09, 2014 12:16 am
by ross_jsy
Any advice on what to use to get the engine bay spotless? Took the lump out yesterday and it's in a bit of a mess so want to clean it up and sort a few rust bubbles.
Cheers guys
Re: Cleaning the engine bay
Posted: Sun Nov 09, 2014 12:19 am
by jimbom30cab
Scrub with white spirit, remove all rust with dremmel, prime fill and flatten as required, send to body shop for new paint.
Well worth it.
Posted: Sun Nov 09, 2014 12:44 am
by Z3I
Auto Glym Engine and Machine cleaner, works almost anywhere!
Posted: Sun Nov 09, 2014 12:49 am
by rich318i
TFR = Traffic Film Remover is acid and a works a gem 50/50 mix if pure with water or spray neat and wash off quick just so the oil and grime is waked up to get it off
Posted: Sun Nov 09, 2014 12:54 am
by Kos
Bilt Hamber surfex or autosmart G101
Posted: Sun Nov 09, 2014 6:04 am
by polsta
Z3I wrote:Auto Glym Engine and Machine cleaner, works almost anywhere!
This ! To just remove grime, spray it work in with tooth brush on heavy areas , rinse off, will give you a good idea of what to do next, ie paint or not like Jimbo says , well worth it to do so tho
Posted: Sun Nov 09, 2014 8:14 am
by Jesus325iTouring
If I wasn't on a time schedule to get my Touring on the road I would have cleaned my engine bay, it is black and thick with oil, as it stands now the thick layer of oil can stay put as rust preventative, all be it an unpleasant looking one.
Posted: Sun Nov 09, 2014 10:07 am
by ross_jsy
Cheers guys. I'll probably end up getting it sprayed when I have some body work done.
Just removed all the bulkhead insulation. It's in great condition so there's one last thing to worry about
by ross_jsy
Oh does anyone know if the support behind the lower valance is available? Mines not rotten but it's certainly seen better days
Posted: Sun Nov 09, 2014 11:22 am
by bss325i
It's part of the front panel and they offten get scabby but give it a once over with a wire wheel and you might be surprised how well it will come up.
