I'm such a chicken! Jackpoints...
Posted: Tue Aug 26, 2014 11:42 am
by Wega
I just need to be 100% sure that this is a correct place to put jack stands:
It's ok, you can laugh at me, but I really dont want to ruin my new E30, and I have never jacked up an E30 myself. :mad:
Re: I'm such a chicken! Jackpoints...
Posted: Tue Aug 26, 2014 1:32 pm
by BenHar
Posted: Tue Aug 26, 2014 1:34 pm
by Brianmoooore
Jack stands where you have them puts a lot of strain on the rear beam bushes, BUT no more than a correctly fitted bush in good condition should be able to take. A better (but less safe) place to put them is under the large nuts securing the rear beam, just outside of where the stands are in your pic.
Posted: Tue Aug 26, 2014 2:18 pm
by Wega
Thanks guys, I just needed to be sure.
Went all in to make sure I would be ok if something went wrong:
Brian: You mean this point, right?
Re:
Posted: Tue Aug 26, 2014 3:07 pm
by Rich320I
yes, iv jacked mine from that point many times
Posted: Tue Aug 26, 2014 3:31 pm
by G-Bear
Nothing to be worried about asking, everyone has to start somewhere, I had the same worries when I first started tinkering with cars... I used to jack my car up through gritted teeth...
Posted: Tue Aug 26, 2014 6:40 pm
by daimlerman
Another option is to make up a few packing pieces from plywood and use the rear cill jacking point for your stands.
Posted: Tue Aug 26, 2014 6:51 pm
by Wega
Thanks for all you comments, it all went fine and now I know how to do it next time. But it really isnt comfy lying under the car and working, I envy those with a lift :)
Posted: Tue Aug 26, 2014 9:09 pm
by maxfield
Posted: Tue Aug 26, 2014 9:18 pm
by Brianmoooore
daimlerman wrote:Another option is to make up a few packing pieces from plywood and use the rear cill jacking point for your stands.
That's what I have, and do, to raise the car with a jack, but you can't put stands in the same place as the jack!
Posted: Tue Aug 26, 2014 9:41 pm
by daimlerman
I raise the car using either 'drive on' ramps or jack under the diff or the beam bush mounts to get the thing high enough to support by the cills.
I guess that it's personal choice just how you get the car high enough to work under in reasonable comfort.
Even my new 'man-cave' that is currently at foundation level will not be high enough to allow a 2 post lift! :cry:
