Suspension pads
Posted: Mon Jun 23, 2014 11:29 pm
by mods
Hi im going to fit pro sport coilovers to my cab, i was thinking of fitting new rubber pads, im a bit confused as thier are few different sizes in thickness in them, why is that? Also would it be wise to change the front and rear top mounts as well, thanks
Re: Suspension pads
Posted: Mon Jun 23, 2014 11:51 pm
by Speedtouch
It's similar to the '80s Mercedes, so you could adjust the ride height without having to change the springs.
Quite handy if a previous owner has fitted lowering springs and your sump keeps getting knocked, like on a Merc 190E I once owned.
Re: Suspension pads
Posted: Tue Jun 24, 2014 12:03 am
by mods
Should i go for the thicker ones and i could adjust them with the coilovers as i want a decent stance not to low and would like it to be comfortable as well when driving. What are costs for front and back. Cheers
Re: Suspension pads
Posted: Tue Jun 24, 2014 12:28 am
by Speedtouch
Go for a size that give you an appropriate ride height with the springs you are using.
For prices, try asking Cotswolds on here...
Re: Suspension pads
Posted: Tue Jun 24, 2014 12:53 am
by mods
Thanks will check them out.
