double sided issue
Posted: Thu May 15, 2014 2:12 pm
by SHAKEELE30
ive been trying to use a double sided tape to stick my number plate onto my car, but end up loosing the plates as they just keep coming off...
can anyone recommend a double sided tape, ive used the green one, another white foam type called sellotape...
any others?
Re: double sided issue
Posted: Thu May 15, 2014 2:31 pm
by ross_jsy
The 3m stuff is what I have always used with no problems
Posted: Thu May 15, 2014 2:32 pm
by afromaan
Try the 3m foam strips from whsmiths. I've used them before and they are perfect.
Posted: Thu May 15, 2014 3:08 pm
by bdx
3M VHB
Posted: Thu May 15, 2014 5:01 pm
by Brianmoooore
Strips were probably OK - it's the surface preparation that's important. If you stick the strip to a film of whatever is on the base material (bumper, rear panel, or numberplate) the strength of the bond is the strength of the bond between the film and the base material.
Posted: Thu May 15, 2014 6:08 pm
by scallyally
Used to work for Avery Automotive at Thurrock and their range of d/s tapes were very good, particularly "666" and if surface prep was good and clean (and I mean clean!) you could not budge it (excessive heat might)
3m is good but foam tapes have to rely on the "shear" strength of the foam. Good luck :x
Posted: Thu May 15, 2014 7:39 pm
by capnmchl
I've noticed with my front one it's not the actually sticky part of the tape that's failing, it's the foam that disintergrates and peels away from the tape.
Posted: Thu May 15, 2014 10:13 pm
by Rav335uk
Try using 3M tape.
Posted: Sat May 17, 2014 2:27 pm
by jotz
As Mr Moooore said Shak
Make sure both surfaces are really clean. No dust, polish, silicone.
Always found 4 strips vertically ( 1 inch each) should do the job. 3m is fine green stuff.no need to get complicated.
Clean with methalated spirits first.... and if that dont work at least you can drink the rest of the bottle whilst you whack a few 4'Nails in!!!
Posted: Wed May 21, 2014 8:26 am
by SHAKEELE30
you back then jotz?
Re:
Posted: Wed May 21, 2014 10:12 am
by Ianb
One thing nobodys mentioned is temperature. I have found that the doublesided tabs work much better if thet are applied when the surface ( and air temp ) is warm.
Posted: Wed May 21, 2014 12:23 pm
by SHAKEELE30
does anybody where I can go and buy some 3m foam tape, ive been to whsmith but they only do a very thin one... any specialist shops etc that I can go in a purchase not online...
Re:
Posted: Wed May 21, 2014 12:49 pm
by Gert_8
What you need is a product called "Tissue Tape". This is a very thin double sided tape ideal for your needs. Check it out on the following website: www.ukpos.com
10mm roll or 20mm options.
Re:
Posted: Wed May 21, 2014 2:18 pm
by G-Bear
Agh feels good to be back on here. Have been busy getting married. But now life (hopefully) restores back to normal; working on my touring.
Have a look on here. Never bought double sided tape off them but their gaffer tape is good.
http://www.gaffatape.com/Double-sided-t ... fault.aspx
Re:
Posted: Wed May 21, 2014 2:40 pm
by Gert_8
Congratulations, G-bear! :D good to have you back.
Re:
Posted: Wed May 21, 2014 2:42 pm
by jotz
winterbourne road , Thornton heath. Capital car colours
Re:
Posted: Wed May 21, 2014 3:07 pm
by G-Bear
Gert_8 wrote:Congratulations, G-bear! :D good to have you back.
Thanks Gertman :D. Enjoying catching up with it all.
Re:
Posted: Wed May 21, 2014 3:10 pm
by Gert_8
The interesting threads are the ones with Pony and Rossy in them.. :D
Re:
Posted: Wed May 21, 2014 3:20 pm
by G-Bear
Note taken.... E30Enders?
