lower arms
Posted: Thu Jan 09, 2014 10:07 pm
was gonna get some old ones and referb is there a wiki page on this or is it a case of removing replace and refit
Can be done fine without a press, just takes some alternative thinking and careful hammer wielding.Grrrmachine wrote:There's no Wiki article, as it's only five nuts and a ball-joint splitter you need to get the control arm off. But you won't be refitting the ball joints to the arms yourself - my garage had to send mine elsewhere, as their 20-tonne press wasn't up to the job
I've developed my own technique for this. I take a small well worn screwdriver, whose tip is well rounded off at the corners, and force it between the pin and the bush. I then push the extension tube on an aerosol can of silicon grease in beside the screwdriver and squirt a burst of grease in. Repeat the procedure at several points around the pin, and you will have unstuck the rubber from the metal, and introduced a lubricant between the two, enabling the bush to be pulled and twisted off.TheDutch wrote:Is it possible to remove and refit a good condition control arm bush from one arm to another?
If you price your time at, say £50 ph, how cost effective is your technique?Brianmoooore wrote:I've developed my own technique for this. I take a small well worn screwdriver, whose tip is well rounded off at the corners, and force it between the pin and the bush. I then push the extension tube on an aerosol can of silicon grease in beside the screwdriver and squirt a burst of grease in. Repeat the procedure at several points around the pin, and you will have unstuck the rubber from the metal, and introduced a lubricant between the two, enabling the bush to be pulled and twisted off.TheDutch wrote:Is it possible to remove and refit a good condition control arm bush from one arm to another?
It's important that all traces of the silicon grease are removed before reusing either part, otherwise the pin bush might slide on the pin when put back into use, instead of the rubber twisting.
If the arm and bush/lollipop are off of the car, it takes just a couple of minutes with the arm in a vice to get the bushes off.hennared323i wrote:If you price your time at, say £50 ph, how cost effective is your technique?Brianmoooore wrote:I've developed my own technique for this. I take a small well worn screwdriver, whose tip is well rounded off at the corners, and force it between the pin and the bush. I then push the extension tube on an aerosol can of silicon grease in beside the screwdriver and squirt a burst of grease in. Repeat the procedure at several points around the pin, and you will have unstuck the rubber from the metal, and introduced a lubricant between the two, enabling the bush to be pulled and twisted off.TheDutch wrote:Is it possible to remove and refit a good condition control arm bush from one arm to another?
