bmw e30 2.7
Posted: Fri Nov 15, 2013 11:43 am
by bem
Hi,
I wonder if anyone can help, driving my car Sunday then all power went turned the car off then back on and was fine then done it again done the same again but as been fine since, its like its something electrical any ideas thanks.
Re: bmw e30 2.7
Posted: Fri Nov 15, 2013 11:57 am
by miniblob
Loose connection on the battery???
Went through a little phase where my -ve terminal was knackered and kept coming loose!!!
Re: bmw e30 2.7
Posted: Fri Nov 15, 2013 12:05 pm
by daimlerman
Crank position sensor?
Re: bmw e30 2.7
Posted: Fri Nov 15, 2013 12:22 pm
by Grrrmachine
what do you mean by "all power went". All engine power, or all electrical power?
Re: bmw e30 2.7
Posted: Fri Nov 15, 2013 12:23 pm
by jimbom30cab
DME relay coming loose ?
Re: bmw e30 2.7
Posted: Fri Nov 15, 2013 1:02 pm
by Speedtouch
Also check the engine-to-body earth strap is securely connected.
Re: bmw e30 2.7
Posted: Fri Nov 15, 2013 1:52 pm
by bem
Just been out again and let it warm up 1st then pulled away and under load just went dead, like i ad run out of fuel but loads in there, turned the ignition off then back on and has been fine on a run, going to let it get cold and try again, thanks for replies I will check them out.
