E30 Sunroof Seal
Posted: Mon Jul 01, 2013 6:01 pm
by Jamie8GTi
Hello guys, got a 89 316i 4 door with the manual sunroof and am looking to get a replacement gasket for the sunroof
I dont mind either the two piece or one piece but im having trouble trying to find one in this country and bellow $100
Could anyone point me in the right direction?
The car is being resprayed and rather stupidly I removed the old perished seal before looking into its replacement..
Thanks, Jamie
Re: E30 Sunroof Seal
Posted: Mon Jul 01, 2013 6:29 pm
by Automaton
I ordered one from Schmiedmann.com
Posted: Tue Jul 02, 2013 11:10 pm
by oomz1975
Got mine from Cotswold BMW.
Posted: Tue Jul 02, 2013 11:12 pm
by magpie
i've got a good second hand one here Jamie.
Posted: Tue Jul 02, 2013 11:43 pm
by DmcL
got a new one peice one a few years ago for mine but never fitted it yet. if i recall it wasnt very much..
i got it from border motorworks over here in NI, they post stuff out no problem so maybe worth an email to see how much?
http://www.bmwspareparts.com/index.html
just dont mention dan or the E46 touring rear shocks i still havent dropped down to him from months ago, he needs to open on weekends again so i can give him these feckin shocks sometime this century lol
Posted: Wed Jul 03, 2013 1:55 pm
by scott320i
I'm about to buy a new roof seal for my E30, what is the difference between the one piece type and the two piece type??? My car seems to have two piece type , the car has had a very sketchy past and been rebuilt a few times
it's a 83 320i has the type of roof that doesn't have the pop up wind deflector in
Posted: Fri Jul 05, 2013 4:27 pm
by Jamie8GTi
Mines the pop up.. i would have thought they are all the same.. the only real difference between the two is that theres only one join? tbh i can only see it being a good thing i posted a topic on the cotswold bmw part of the forum and was quoted about 100 for the two piece seal and then 60 for the single so i will definitely order the single
Posted: Fri Jul 05, 2013 9:23 pm
by Tony_R
Posted: Thu Jul 11, 2013 7:49 pm
by scott320i
Jamie8GTi wrote:Mines the pop up.. i would have thought they are all the same.. the only real difference between the two is that theres only one join? tbh i can only see it being a good thing i posted a topic on the cotswold bmw part of the forum and was quoted about 100 for the two piece seal and then 60 for the single so i will definitely order the single
I got one today from Parklane BMW as I was on a tight shipping schedule ... I got the one piece type , the two piece type have slightly different profiles AKA front is slightly diff to rear,although they are the same from the top
The only thing i can think of between the two variants may be some sunroofs have a factory inbuilt pop up steel wind deflector mine dose not have this and cannot be fitted with one
Posted: Sat Jul 13, 2013 9:28 pm
by Jamie8GTi
Ah, mine has the factory pop up wind deflector.. Maybe the difference in profile of the front of the two piece seal is to fit over it when down... Anyone know for sure?
Posted: Sat Jul 13, 2013 10:09 pm
by magpie
if you have a leak seal and your roof still opens clean up the seal and the moss from the edges of your roof .
Posted: Sat Jul 13, 2013 11:55 pm
by Brianmoooore
magpie wrote:if you have a leak seal and your roof still opens clean up the seal and the moss from the edges of your roof .
?? If you have a (rain water) leak, it's NOTHING to do with the seal. It's not supposed to keep all water out.
Posted: Sun Jul 14, 2013 12:47 am
by e30topless
the sunroof panel seal does help keep out most of the water but not all of it, the sunroof cassette will catch the rest, that's how it's designed to work..
the one piece seal is shite and will NOT work correctly, they foul the operation of the tilt action because of the continuous rubber edge all the way around, this makes it stick during operation..
the proper 2 piece seal has a fibre edge on the rear section to aid movement and helps the sunroof panel to drop down correctly and sit flush in the closed position, sadly they are now costly to buy new...
most are serviceable as mick says, clean up the trailing edge they are always covered in Mossy type shite and grime, chances are it will still be up to the job...
Posted: Sun Jul 14, 2013 8:41 am
by scott320i
Jamie8GTi wrote:Ah, mine has the factory pop up wind deflector.. Maybe the difference in profile of the front of the two piece seal is to fit over it when down... Anyone know for sure?
That's what I was thinking....
The brand new seal from BMW has a fibre edge all the way round.... It's just a continuos rubber/ fibre edge profile
It looks the same as the rear of the 2piece type but will confirm that in a few days
Posted: Mon Jul 15, 2013 1:04 pm
by Jamie8GTi
two piece seal it is for me i reckon! i've been quoted for both through cotswold and two piece is slightly more but if it works its worth it
Posted: Mon Jul 15, 2013 1:13 pm
by scott320i
Ill post how the single piece does when I fit it
Posted: Tue Dec 10, 2013 6:05 pm
by scott320i
[the one piece seal is shite and will NOT work correctly, they foul the operation of the tilt action because of the continuous rubber edge all the way around, this makes it stick during operation..
[the proper 2 piece seal has a fibre edge on the rear section to aid movement and helps the sunroof panel to drop down correctly and sit flush in the closed position, sadly they are now costly to buy new...]
well 6 months on with the brand new genuine BMW 1 piece seal
all i can say is theres no difference it works fine
and this talk about the continuous rubber edge ...well my 1 piece has the fibre its simply a length cut off a roll
it tilts perfect and dose everything normal
Posted: Tue Dec 10, 2013 7:48 pm
by GooneriC
I bought a one piece from Bavarian Auto in the US for $82 and it had the same edge as the old 2-piece i took off , no problems with it so far.
Posted: Tue Dec 10, 2013 9:54 pm
by scott320i
he 2 piece seal has 2 different profiles ,my one piece seems to be the same profile as the smaller profile , im guessing all the one piece genuine types would be the same
