No heating in winter not fun !
Posted: Wed Jan 30, 2013 5:25 pm
by skivvey
Back again got a grinding noise from the heaters when I turn them on some heat blows out but not very much I was given a new heater blower with the car but could be something else ? Also I seem people use an access panel in the bulk head can I remove it from here or will I need to go in from the dash ? Thanks guys
[/i]
Re: No heating in winter not fun !
Posted: Wed Jan 30, 2013 6:05 pm
by PG325
Fan is accessed via the bulkhead panel in the engine bay, pop the cover, disconnect the wiring, unclip the fan and remove. Best to apply 3 in 1 oil to the bearings and leave to soak for as long as possible.
Plenty of pics using the search facility.
Posted: Wed Jan 30, 2013 6:06 pm
by kolee
From thewiki:
Heater Blower
In order to move the air around the cabin you need a form of fan, which in the E30 is called the Heater Blower. Rather than a bladed fan like an aeroplane's propellor, the heater blower looks like an old paddle steamer with two bladed wheels. These are driven by a centrally-mounted motor, and then the whole assembly is mounted on to the top of the heater matrix.As a unit, it's accessible from the engine bay, where it sits just behind the bulkhead covered by a panel in the scuttle. There is no need to dismantle the interior of the car to access it.A variety of blowers were fitted during the lifetime of the E30. Facelift motors (1987 onwards) are different from pre-facelift, and aircon motors are different from facelift. However, facelift aircon fans are very similar to the pre facelift version, and are possibly identical. This is very important when sourcing a replacement, since there is no chance of fitting a pre facelift motor and fan to a non aircon facelift heater box.
Posted: Wed Jan 30, 2013 6:16 pm
by moggie
mine was doing the same mate,i removed via the access panel and oiled it up and its as good as new!very easy to do
Posted: Thu Jan 31, 2013 12:58 am
by skivvey
Thanks guys was hopping it was from the bulk head really didn't want to go taking the dash apart thanks will do this in the morning
Posted: Thu Jan 31, 2013 10:34 am
by e30kid6
I've got a similar problem but mine works generally okay, but whistles a lot, or squeaks sometimes, could the oil be the solution to this problem as well?
Posted: Thu Jan 31, 2013 10:37 am
by FinalD
Worth giving it a blast with WD40 / 3-In-1 to see if that fixes it.
One of mine was only working at full speed on 4 and about half speed on 3, nothing on 1 or 2. My spare was running full speed on 4, slower on 3, slower on 2 and not on 1. Gave them both a good blast and soaking with a can of oil and it appears that my original was just knackered but the spare now works properly on all 4 speeds.
The only down side is you get a strong whiff of WD40 in the cabin for a bit.
Posted: Thu Jan 31, 2013 1:51 pm
by Brianmoooore
The job can't be done properly without taking the motor out and powering it up in your hand with a battery. Free it up with WD40, then lubricate properly with a light oil, moving the shaft from side to side to work the fluids in.
Posted: Tue Feb 05, 2013 3:49 pm
by skivvey
All done now
had trouble figuring out how to in lip the motor but got there in the end and all working now but got a strong smell off wd40 lol I soaked it in it over night so all bearings moving nice a free on the new motor thanks guys also if u got a strut brace u gotta take it off as I found out lol
