Breaking in..
Posted: Fri Mar 16, 2012 11:20 am
by savagehenry
I have asked about this before, but I was still holding out that the keys for my 325 parts car would turn up...but no luck.
People have told me to take out the front screen, but don't you have to push the window out from inside the car? I can't damage the screen because it is un-marked and I want it for my touring.
I know this might seem a stupid question but as it's a saloon(5 door) would it be possible to break the quarter glass and pull the handle while someone pulls on the outside. I sure the door will be sticky too as the car has sat for years. Or will the door still not open because of the central locking?
With spring approaching I need to get the decent wings off it for my touring. and I've been held up by my mate trying to find the keys. It's got to the point where I will break the side window if I have to and climb in to pop the bonnet. but as I will need to keep the car water-tight to save the seats, less damage the better.
Any (more) ideas?
Thanks.
Re: Breaking in..
Posted: Fri Mar 16, 2012 11:30 am
by capri_rob
You can pop the bonnet with the car locked - IIRC you need to remove one of the front grilles - either that or there is an access hole - its for if the bonnet cable snaps.
Re: Breaking in..
Posted: Fri Mar 16, 2012 12:03 pm
by daimlerman
I would go with taking the windscreen out.
Remove the small metal covering clip on the lower run of the rubber,then pull the locking strip out.Ease the seal from the glass,and lift it out.A pair of those sucker thingys would be handy,as will an extra pair of hands.You will be suprised at how far the 'screen will flex....
Re: Breaking in..
Posted: Fri Mar 16, 2012 12:06 pm
by hazd31
daimlerman wrote:I would go with taking the windscreen out.
+1 on this
Use a couple of wooden spatulers from the kitchen to gently ease the seal along, its very easily done!
Re: Breaking in..
Posted: Fri Mar 16, 2012 12:08 pm
by andyp
is it dead locked ? with key barrel facing side ways ?
Re: Breaking in..
Posted: Fri Mar 16, 2012 12:09 pm
by Tom_Maverick
snap the aerial off.. go and buy some this metal centred garden plant twine (the flat plastic stuff.. it's green and is a couple of quid for a big reel from B&Q)) thread it through the centre of the aerial tube.. make a small loop in the end, pull the top of the door and wedge it with a flat bladed screwdriver, (you can actually pull them open quite far without much damage!) then just noose the knob with the small loop while directing the wire with the aerial tube, pull fairly tight with the tube and then pull steadily up and voila..
it's technically known as a 'slim jim' .. I have made them out of all kinds of things including hacksaw blades etc.. (you just thread the twine through the hole in the end and bend the blade to suit.. handy as its flat) but the principle is the same.. E30's are easy to break into sadly...
Re: Breaking in..
Posted: Fri Mar 16, 2012 12:33 pm
by Duke137
Have a prod around the front jacking point with a screwdriver and then go at it with a knot brush. Most E30's have an access point for a small child here who could go in and unlock it for you.
Re: Breaking in..
Posted: Fri Mar 16, 2012 12:41 pm
by 318isPMK
just stick your hand through one of the rust patches and crawl in from underneath?
Re: Breaking in..
Posted: Fri Mar 16, 2012 12:43 pm
by gudgeon
Very funny Duke, I had 2 of these access points but I welded them closed as my wife kept complaining that her shoes were being scuffed on the road surface.
Posted: Fri Mar 16, 2012 1:36 pm
by boomerm20
The last time I got locked out of my e30,I called a road service truck that used an airbag device to create a gap between the B pillar and the body of the car.He then used a hook to pull up the lock.Took about 20 minutes total.
Posted: Fri Mar 16, 2012 1:49 pm
by Tom_Maverick
boomerm20 wrote:The last time I got locked out of my e30,I called a road service truck that used an airbag device to create a gap between the B pillar and the body of the car.He then used a hook to pull up the lock.Took about 20 minutes total.
thats just a posh version of my trick :)
honestly.. B&Q twine and a bit of pi**ing about and you'll be in in minutes!
Re:
Posted: Fri Mar 16, 2012 2:14 pm
by steve_k
To the OP pm on it's way ;)
Re: Breaking in..
Posted: Fri Mar 16, 2012 2:26 pm
by capri_rob
Duke137 wrote:Have a prod around the front jacking point with a screwdriver and then go at it with a knot brush. Most E30's have an access point for a small child here who could go in and unlock it for you.
Epic :lol:
Re: Breaking in..
Posted: Fri Mar 16, 2012 3:07 pm
by stew72
you're in Kings Lynn. Push it to the fairstead.
Posted: Fri Mar 16, 2012 3:20 pm
by capri_rob
Won't work if its deadlocked.
Re:
Posted: Fri Mar 16, 2012 3:39 pm
by assassin
Flat, plastic parcel binding. 8 seconds tops. I just timed myself trying it on mine. Old habits, and all that.
Re:
Posted: Fri Mar 16, 2012 3:40 pm
by bodger
Why not pull the rear screen out if your worried about breaking the front screen
Re:
Posted: Fri Mar 16, 2012 4:05 pm
by Jim320i
If you end up going down the smashed window route... I have Genuine Replacement replacements :cool: :twisted: winkeye
Smash the fooker. Then Pm me. :D
Re:
Posted: Fri Mar 16, 2012 4:10 pm
by gudgeon
As someone has already said, if it's deadlocked you still won't be able to use the driver door, have to use the passenger door.
How about drilling out the damned lock barrel.
Re:
Posted: Fri Mar 16, 2012 6:34 pm
by Brianmoooore
If it's deadlocked you won't be able to open the passenger door, the boot or any other door. That's the point of deadlocks.
I've seen my brother in law open a car door by hooking up the lock pin in only a very slightly longer time than it would have taken him with the key. Pulling out the top of the door shouldn't damage anything, and if you do overdo it and bend it out slightly, it's easy enough to bend back in again.
I've made a slight 'adjustment' to the top door frame of many cars, including E30s, to cure wind noise.
Re:
Posted: Fri Mar 16, 2012 6:44 pm
by DanThe
Threads like this is why I like to fit cabby door pins :)
Re:
Posted: Fri Mar 16, 2012 6:49 pm
by Duke137
Yeah this wants deleting!
Re:
Posted: Fri Mar 16, 2012 7:40 pm
by Brianmoooore
There's nothing in this thread that all the thieving scrotes out there won't already know!
Re: Breaking in..
Posted: Sun Mar 18, 2012 7:35 pm
by savagehenry
stew72 wrote:you're in Kings Lynn. Push it to the fairstead.
Haha....they will come out like rats and there will only be a shell left!!
Maybe a nicer shit-hole like south-lynn would be better
I've seen broken down cars that have been left for more than 2 days get chucked on a hi-ab... for a weigh in. People turn up with jump leads but the problem has already been solved!! lol.
Re:
Posted: Sun Mar 18, 2012 7:38 pm
by savagehenry
gudgeon wrote:As someone has already said, if it's deadlocked you still won't be able to use the driver door, have to use the passenger door.
How do you do this??
Re: Breaking in..
Posted: Sun Mar 18, 2012 7:40 pm
by savagehenry
I know you are right...that's why I don't want to look. lol.
Re: Breaking in..
Posted: Wed Mar 21, 2012 7:30 pm
by savagehenry
This is the car (2 good wings, in black) and how the lock sits.
Re: Breaking in..
Posted: Wed Mar 21, 2012 7:40 pm
by capri_rob
Thats deadlocked - pulling up the door-pins won't work.
Screwdriver time ! :eek:
Re: Breaking in..
Posted: Wed Mar 21, 2012 7:51 pm
by savagehenry
capri_rob wrote:Thats deadlocked - pulling up the door-pins won't work.
Cheers... that's what I was trying to get to the bottom of. everyone was giving up their quick break in methods but forgot about this.
I must admit I wasn't sure if it was dead-locked or not.
Now what will I gain from knocking that lock in??? People have been telling me to do this..how will that help un-lock the door?
:o:
Re: Breaking in..
Posted: Wed Mar 21, 2012 8:28 pm
by Brianmoooore
Still worth a try on the passenger door pin. Lots of E30 deadlocks don't work properly, and there's a good chance you'll get lucky.
Doesn't do any damage, and doesn't take long, so why not?
Re: Breaking in..
Posted: Wed Mar 21, 2012 8:37 pm
by fowler
has it got windy windows at the back or leccy ? ther is a trick to get in with out smashing or drilling anything
