rear beam rage!
mrb27
Sun Jan 15, 2012 7:35 pm
hey guys, just spent the day crawling around under the car dropping the rear beam, thought id start with that first as im giving the car a full rebush and lots of x.mas prezzies and tlc..
there was me thinkin it would be a breeze eh.. lol at that!
its been a fukker!! to say the least, from start to finish! well i say finish.. i got to fit it all bk up again yet :eek:
if it wasnt nuts ringing off it was snapped bolts!! and if not that it was the bloody 2 allen key bolts that hold the beam cup to the underside.. they rang off and when i slipped i punched the floor with so much force i was pickin grit out of my knuckles for 30 mins!! well that was after i raged and grabbed the grinder and attacked em :evil:
and after it all i find my blow torch is fooked so i have no means to get the bushes out :cry:
oh yh and im also gonna have fun drilling out the tops of the beam bushes that have broke off in the hole all nice and flush!!
well i have to say i do feel better now ive had a moan lol
Uploaded with ImageShack.us
fuzzy
He who sleeps with "Gingers"
Sun Jan 15, 2012 7:36 pm
sometimes its better just to give it to a garage and pay for someone else to sort the problem jobs.
danryan
Sun Jan 15, 2012 7:50 pm
how long would a garage on average need to change the rear beam bushes?
kam-325i
Sun Jan 15, 2012 7:52 pm
danryan wrote:how long would a garage on average need to change the rear beam bushes?
When i used to use Moseley Motors, i would drop the E30 of in the morning around 8, and it was ready around 1-2....
danryan
Sun Jan 15, 2012 7:58 pm
the bushes are cheap enough, but quite labour intensive then. i was going to get danthe to powdercoat a spair rear beam and fit the bushes. then i was going to ask my local bmw garage to fit it. ££££
mrb27
Sun Jan 15, 2012 8:03 pm
id much rather do it myself, plus this is the only job the the e30's ive not actully done before, you should see the handbrake shoes lol, there is a spot of about 10mm of meat on the whole shoe, the rest has broken down...
fuzzy
Sun Jan 15, 2012 8:04 pm
im sure i got charged £100 and i supplied the parts from a local small garage but that was a couple of years ago now.
Sun Jan 15, 2012 8:06 pm
been there done that,bonding is what it's about.
:cens:
have a read of this.
http://www.e30zone.net/modules.php?name ... &start=600
danryan
Sun Jan 15, 2012 8:20 pm
wow, theres alot more involved when changing the beam, bushes etc. might as well do it all properly. its getting even more expensive 8O
Sun Jan 15, 2012 8:25 pm
tell me about it,
at least it'll survive Poddington 2012 :D
Sun Jan 15, 2012 9:09 pm
Dont forget these once your on the rebuild -
http://www.e30zone.net/modules.php?name ... c&t=208635
Sun Jan 15, 2012 9:10 pm
check :D
Grrrmachine
E30 Zone Wiki / Team Member
Sun Jan 15, 2012 9:13 pm
I know what you mean. I took the allen key bolts off in December, and the beam is still sitting on my garage floor! Allen bolts had to be sliced off, bush rubber had to be drilled out, it still took crowbars to prise the beam down, took a day to bash the old bushes out and wind the new ones in...
and I still haven't done the trailing arm bushes yet! 20 broken nuts and a whole meter of broken threaded bar, and not one of the coonts has gone back in.
Still, at least the car and I are having some quality time together.
Sun Jan 15, 2012 9:19 pm
immit :D
Sun Jan 15, 2012 9:37 pm
I just dont understand how so many people make such a meal out of removing a rear beam :?
Sun Jan 15, 2012 9:39 pm
DanThe wrote:I just dont understand how so many people make such a meal out of removing a rear beam :?
beam virgins :mrgreen:
Sun Jan 15, 2012 9:43 pm
Read some threads on here before you start then! :)
MattTheHat325
Sun Jan 15, 2012 9:44 pm
I'm due to do this over the coming months, how does it compare to an e36? As I did my tourer a couple of months back and apart from removing the old bushes it was a piece of cake. Obviously the e30 has been exposed to crust for 10 years longer :eek:
Sun Jan 15, 2012 9:51 pm
some like to share their pain .
Sun Jan 15, 2012 9:53 pm
I will break it down into 12 easy steps -
1 Remove exhaust
2 Remove driveshafts
3 Separate diff from prop and remove diff from beam
4 Release handbrake cables from lever and pull through to outside of car, if seized use 5 mole grips to free from body tubes.
6 Separate ARB links from trailing arms
7 Separate brake pipe hard line from flexi at trailing arm to body point
8 Separate damper from trailing arm
9 Remove rear springs
10 Remove trailing arms
11 Remove bush base plates
12 Remove rear beam BY HAND WITH EASE, no pry bars, sledge hammers, gas axe, blood, swearing or jumping up and down like a red faced farmer required :P
Sun Jan 15, 2012 9:55 pm
clear as mud Dan :D
mrb27
Mon Jan 16, 2012 12:21 am
DanThe wrote:I will break it down into 12 easy steps -
1 Remove exhaust
wow if i knew it was that easy i would have got the missus to do it :P
you make it look so easy, if only...
yes i am a beam virgin :o: but gotta learn somehow :wink:
Grrrmachine
Mon Jan 16, 2012 6:51 am
1 Remove exhaust - using an angle grinder to lop off the nuts
2 Remove driveshafts with whatever poxy allen key you can get into the nuts
3 Separate diff from prop and remove diff from beam using one arm to support the 40kg while you effortlessly undo the nuts located on top of the thing
4 Release handbrake cables from lever and pull through to outside of car, if seized use 5 mole grips to free from body tubes which you will manipulate with all five of your arms at once...
Piece of cake 8)
Mon Jan 16, 2012 9:00 am
What most dont understand is by leaving the diff and arms attached you are making it much more difficult to remove, the weight all at the back is just twisting the beam bushes against the studs, if you knock the studs out the twisting force is on the alloy sleeves which are located in the body, the weight/twisting force (not corrosion) will break these off as many experience.
It is possible to remove the lot in one go but you can only do it by keeping the weight off the beam as it comes down which is very difficult with the car on axle stands.
greggers
Mon Jan 16, 2012 1:53 pm
1 Remove exhaust
Did you mean to miss hammering the bolts back into the car?
I have to say that I followed those exact steps and the beam didn't just drop off. The metal tubes in the bushes had bound themselves to the car. So I got an old flat blade screwdriver, put it down the hole from the inside of the car so it stuck out the bottom, then wound the biggest screw extractor I had into the steel bush liner so it gripped both the screw driver and wall of the liner, then hit the screw driver a few times from the inside and it eventually fell out. I don't care if it's a bodge, it worked for me.
I had tried with the crowbar, but the rubber just stretched, my way (if you use an already knackered screwdriver) you don't stand a chance of ruining anything.
Mon Jan 16, 2012 6:14 pm
Well yeah thats one way to do it, you can also remove the bolt, push it up the sleeve from underside and wiggle it free
Cypriotgeeza
Mon Jan 16, 2012 9:33 pm
All depends on what kind of life your car has had..im positive the rear end on mine had never been apart untill i got to it 8O
i didnt enjoy it at all! handbrake cables seized..bushes seized onto the bolts..
but the end result speaks for itself :D well worth the late nights after work and hassle!
http://www.e30zone.net/modules.php?name ... sc&start=0
^^ go to page 3 if you want to see my rear end overhaul mate ^^
:thumb:
Check my M30 build threads:
Mon Jan 16, 2012 11:41 pm
i totally enjoyed snapping bolts and getting covered in sealer,underseal and waxoil .
nice :evil:
mrb27
Wed Jan 18, 2012 12:10 am
i did leave the arms on but did remove the diff for the twisting reason. was still a pain though.. well at least that job is jobbed winkeye
next up the front end :D
tom325sport
Wed Feb 22, 2012 11:24 pm
Yep been there done that!! Worst job on my e30 so far!
davethegoat
Thu Feb 23, 2012 1:13 am
1 Remove exhaust
Mine went pretty much like this, except for stage 12!
The bush centres were wearing some corrosion which had kindly bonded them pretty well to the mounting points. Luckily I had a piece of foot long straight bar which fitted almost perfectly into (or should that be up? winkeye ) the bush. A bit of WD40 and some hefty hammer blows fore and aft did the trick, but it was by no means a breeze. :surrender:
Martinaston
Thu Feb 23, 2012 10:03 pm
After doing a few of these the best way i've found is to drill/saw out the rubber and remove the beam then gently tap the tube side to side, or use a round pry bar up the hole and wiggle it by hand.
There is NO nucleus.
tim_s
Thu Feb 23, 2012 10:39 pm
No-one else does these in place then? I've done these a few times just by removing wheel, lower shock bolt, undoing subframe bush nut and carrier etc, whacking the bolt through into the interior then getting the bmw extendable wheel wrench, sticking it into the subframe bush and giving it a good wiggle (oo er) (actually sometimes needs the persuader to come free) to free the subframe. Then burn/crowbar out old bush, drift in new one. On a good day, half hour a side.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
