Page 1 of 2
M20b25 mpg?
Posted: Fri Dec 16, 2011 10:37 am
by Hayden0
What mpg are you guys getting? I'm averaging 16.5mpg? I've no idea if this is right or not? Just seems abit rubbish to me?
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 10:43 am
by popey7676
I would expect between 270 and 330 miles to a tank, depending on how you drive it! So 16 is very low
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 10:48 am
by Morat
I can easily see 18 on the OBC doing short hard runs - and 25 on the motorway.
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 10:50 am
by suchy
14.9mpg on Tesco fuel
17.5mpg on Asda fuel
both combined
on a run 20mpg.
I have problems, sounds like you do too I'm afraid...
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 10:51 am
by suchy
Never going to be high with an M20 engine though! But the sound...oh the sound
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 10:58 am
by Tom_Maverick
well, I've been doing a bit of testing and I seem to be averaging about 22mpg! (and that's a mix between town and motorway, averaging 120 miles a week )
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:16 am
by Hayden0
suchy wrote:14.9mpg on Tesco fuel
both combined
on a run 20mpg.
What sort of problems do you have? I'm using shell fuel aswell.
Thanks for feed back guys!
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:18 am
by Jhonno
What type of driving do you do?
Used to get 30+MPG on the daily mostly dual carriageway commute..
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:20 am
by suchy
Hayden0 wrote:suchy wrote:14.9mpg on Tesco fuel
both combined
on a run 20mpg.
Overfuelling problems!!! Same as you!!
I have a thread in Tech you may wish to read;
http://www.e30zone.net/modules.php?name ... c&t=208867
I'm hoping to get a couple of days next week to have a play and check out all the helpfull advice offered
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:30 am
by Hayden0
Jhonno wrote:What type of driving do you do?
Round town and b roads, I live in West Yorkshire so it's quite hilly. I drive slow most of time then I just open it up in second and let off now and again nothing stupid.
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:33 am
by Hayden0
suchy wrote:Hayden0 wrote:suchy wrote:14.9mpg on Tesco fuel
both combined
on a run 20mpg.
Oh cheers I'll take a look tonight on computer.
I have noticed when holding the rev around 2k I get a jerk from engine like kangarooing but if I give it more gas it stops? I've been thinking about a dodgy injector?
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:37 am
by suchy
Mine is jerky low down on light throttle because of overfuelling. Can't use light throttle in 5th anything below 40mph without similar kangerooing feel- more revs cure it. Bogs down easily without heavy foot application. Loves to rev and burn the fuel though!
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:44 am
by Hayden0
Just sounds like mine, have to do 80 on motorway so it doesn't get on my nerves lol. What are you thinking the problem is with yours? I'm a mechanic myself but I've learnt on the new cars as I'm only 20 so with the car being older than me I'm struggling to get my head round it haha
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:51 am
by suchy
I'm really leaning toward the blue sender (engine temp) not comunicating with the ECU either at the plug conector or at the ECU end. It's very similar to driving with cold start (full choke for the oldies) on permanently. Also I think my throttle position switch (TPS) needs looking at and also throttle adjustment as light throttle really doesn't do anything, peddle needs to be at least half-way pressed to make a difference. If you read my thread you see I have other issues compounding the problem which may differ from your if standard, but the solution is the same! Very helpful info from Zoners on my thread so worth a read
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 11:53 am
by Grrrmachine
Anything below 20mpg on these engines means there's something wrong, unless you drive with your foot to the floor at all times.
Have a read of this:
http://www.e30zone.net/e30zonewiki/inde ... ch_Running
Re: M20b25 mpg?
by Jhonno
OP.
I'd be looking at AFM and blue temp sensor to start.
Re: M20b25 mpg?
by suchy
Hayden0 wrote:Just sounds like mine, have to do 80 on motorway so it doesn't get on my nerves lol. What are you thinking the problem is with yours? I'm a mechanic myself but I've learnt on the new cars as I'm only 20 so with the car being older than me I'm struggling to get my head round it haha
Mine runs best at speed also and is actually more fuel efficient at 90 as it is at 60 (tested!!)
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 12:01 pm
by popey7676
I'd take the throttle body to pieces and give it a good clean out, that would probably cure the kangaroo effect.
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 12:05 pm
by Tom_Maverick
if I just do the dual carriageway jaunt to work then I get similar to this.. it's the stop start 5mph into Brighton of a weekend that ruins those figures!
clearly some of the cars on here need attention!
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 12:22 pm
by popey7676
My old m20 high comp used to average 30 mpg and that was running at 189bhp.
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 12:26 pm
by Hayden0
Thanks for the help guys really appreciated. I've ordered a temp sensor while I'm at work, just short of £4.50 eliminates that sensor.
How do you find out if you have high comp engine or not?
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 12:36 pm
by popey7676
The earlier m20 2.5 pre facelift where high comp
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 12:53 pm
by Morat
Don't forget that tourings have a shorter diff so I'd expect them to return lower MPG overall.
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 12:54 pm
by Hayden0
So on an 89 I'm guessing mines not? I don't know the difference between pre-facelift and facelift? Sorry to be a pain
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 8:18 pm
by HairyScreech
Been done to death and a search would have given you about 4 threads at least.
a health m20 in good fettle should be between 25 and 30mpg combined.
Re: M20b25 mpg?
Posted: Fri Dec 16, 2011 10:58 pm
by clipper
HairyScreech wrote:Been done to death and a search would have given you about 4 threads at least.
I've gone from around 20 mpg to the average of about 27 - 28 on mixed driving.
Thing is it took a long time to get my car running "properly" and there wasn't one definite thing that made it change.
Firstly it appeared that someone had wound in the AFM mixture screw all the way to mask an air leak (this only showed up after H/G change), then I cleaned the injectors, changed the air filter, changed the fuel filter, found two minor leaks, adjusted the valve clearances a thousand times eventually changing the excentrics, discovered that my internal transfer pump was dead and out in a new one and a few more things too, all of which gradually improved the running of the car and at the same time improving consumption.
What I'm saying I suppose is what Brian always says, get the car to as close to tip top condition as you can and it'll run as BMW intended despite it's age!
Re: M20b25 mpg?
Posted: Sat Dec 17, 2011 12:08 am
by magpie
you can service it till your blue in the face.
Re: M20b25 mpg?
Posted: Sat Dec 17, 2011 1:09 am
by HairyScreech
clipper wrote:HairyScreech wrote:Been done to death and a search would have given you about 4 threads at least.
this is always the case, of the ~ 7 m20 engines of several different displacements iv had near to have for any length of time all of them have been mid 20s to low 30s, the only reason i have seen for poor mpg is either: serious mechanical issues - air leaks, ring wear etc.
electrical issues or shady "tuning"/modification.
the benefit of the m50/52 in terms of mpg is its more advanced management, less pumping loss from a maf, it has much better fuel trim, better ignition and can advance the ignition right up to the knock threshold of the fuel in the car via the knock sensing system.
this means a bit more in terms of mpg.
Re: M20b25 mpg?
Posted: Fri Dec 30, 2011 12:56 pm
by Speedtouch
Hayden0 wrote:Thanks for the help guys really appreciated. I've ordered a temp sensor while I'm at work, just short of £4.50 eliminates that sensor.
Look at the machined flat to the right of the inlet side engine mount, just above the block:sump interface. A high comp should be 25 6E, while later low comp is 25 6K.
You may need to use a wire brush and Jenolite rust remover and a bright torch to make out the markings.
Any M20 (B20 or B25) should return 25-26mpg average, if in a good state of tune - these were the official figures when new, and what I used to get out of my two L-Jet 320i and two 325i models, unless I caned them!
Poor economy may be caused by an aftermarket adjustable fuel pressure regulator (FPR) - ensure that you have the correct 3.5 bar regulator on the fuel rail.
Posted: Fri Dec 30, 2011 2:00 pm
by polsta
if get in mine, do a 55 mile round trip to work, town-motorway-town, straight there, and straight back, driving with fuel in mind , i can do it twice on £20
but driving how you "want" to drive, is less
Re:
Posted: Fri Dec 30, 2011 2:16 pm
by hongkongfuey
I did a run to rugby, i was getting 35 average motorway , round town im getting 20 mpg, mine is slightly modded
Re:
Posted: Fri Dec 30, 2011 2:18 pm
by spook
And you dont drive like yer nan
Re: M20b25 mpg?
Posted: Tue Jan 03, 2012 2:19 am
by lukec88
worked mine out at around 23mpg but i dont exactly drive it slowly and i like to have a little slide here and there too ;) its an 89 sport by the way if the diff is being considered in these readings?
Re: M20b25 mpg?
Posted: Tue Jan 03, 2012 8:32 am
by hongkongfuey
The other thing i was going to say was, ive fitted an electric fan , ill probably be told that it has nothing to do with mpg, but it only comes on when its needed, doesnt put a strain on the water pump in any way. And in traffic you cant feel the effects unlike a viscous which can be heard and felt
Re: M20b25 mpg?
Posted: Tue Jan 03, 2012 8:59 am
by Kieran_n22
hongkongfuey wrote:The other thing i was going to say was, ive fitted an electric fan , ill probably be told that it has nothing to do with mpg, but it only comes on when its needed, doesnt put a strain on the water pump in any way. And in traffic you cant feel the effects unlike a viscous which can be heard and felt
How can you get rid of the viscous fan!?
