e30 Drivers door check strap
finlay75
Tue Jul 19, 2011 4:42 pm
Door clicks badly - think the check strap is broken on the inside of the wing. Are these a pain to fix? Cheers
ucpsale
Tue Jul 19, 2011 5:01 pm
Easy to replace, remove door card two 10mm bolts and a hammer to knock the pin out, o/s and n/s front door are the same.
finlay75
Tue Jul 19, 2011 5:20 pm
No welding then? Magic - many thanks!
Tue Jul 19, 2011 9:44 pm
They can be repaired by welding, but it's easier to fit a fresh one!
Don't forget to refit/repair the door plastic membrane properly. It keeps water out.
