brake recommendations
Posted: Sun May 15, 2011 2:24 pm
by tweeks
I am in need of new brakes. The car currently has some drilled discs and carbotech pads i think but i am getting a lot of heat and brake fade. The discs are showing blueing. What brakes would you recommend? The car is a 325 touring it is not an everyday car but is used around town so dont want pads that don't work when cold. But is usedas a fast road car and will be doing a few track days this year so want something to stand up to that abuse. Any recommendations appreciated. Cheers.
Re: brake recommendations
Posted: Sun May 15, 2011 3:58 pm
by Morat
I haven't used them myself yet but having read up on various threads, my next set of pads will be EBC Yellows, probably on standard discs because they're so cheap to replace that I don't mind doing it often.
Have a look through the racing section if you're after the very best.
Posted: Sun May 15, 2011 11:31 pm
by tweeks
just been having a read through some info on ebc brakes. i like the sound of the yellow stuff pads. has anyone used these or the redstuff. what do you think of them? cold breaking, brake fade and dust?
Posted: Sun May 15, 2011 11:51 pm
by e30topless
never had good results from either red stuff of yellow stuff, ?
well serviced calipers with dealer discs and pads are well up to the job for fast road use,
Posted: Mon May 16, 2011 9:50 am
by George
I've always heard fairly uncomplimentary reports regarding EBC Green Stuffs, however the Yellows appear to be thought of as much better. Quite aggressive on the discs though iirc.
As E30 Topless says, proper well serviced brake system - new fluid (maybe 5.1 upgrade), decent OEM discs and pads (ATE etc) should be sufficient for (enthusiastic) road use.
But then again, I drive fairly slowly :P
Posted: Mon May 16, 2011 2:07 pm
by Morat
I've used bog standard Jurid pads up to now, they do work well but I have faded them on occasions.
Posted: Mon May 16, 2011 6:59 pm
by tweeks
What difference does dot 5.1 fluid make. What is standard? Id not thought about the pads being harsh on discs but dont mind replacing them a little more frequently. When you say you have not had good results with ebc what were you not happy aboutwith them. I dont really want to put standard discs and pads on as i used to overheat them on my old 318 tourer fairly regularly.
Posted: Mon May 16, 2011 7:13 pm
by zaust
I use the yellow stuff, They are rubbish when cold. Great on track but terrible if your comming off the motorway. The oem stuff is cheap from sytners at the moment and your best bet for evrey day use.
Posted: Mon May 16, 2011 7:26 pm
by hongkongfuey
gsf sell brembo discs, they were as good as any aftermarket, also i used oem pads
Posted: Tue May 17, 2011 12:03 am
by tweeks
how bad are they when cold. how much does it take to get enough heat in them to start working alright. would redstuff be a better compromise?
Posted: Sun Jul 10, 2011 6:18 pm
by keri-WMS
tweeks wrote: i am getting a lot of heat and brake fade. The discs are showing blueing. .............will be doing a few track days this year so want something to stand up to that abuse.....
Have you had the brakes suffer as a result of the heat? Either boiled fluid (gives you a soft pedal, often goes to the floor), or pad-fade (where the pedal stays hard but there's no brakes/deceleration)?
If you are planning trackdays / real brake abuse then the ideal setup for the job is a proper upgrade (budget depending etc), like our WMS kits: http://www.e30zone.net/modules.php?name ... 9&start=24
tweeks wrote:would redstuff be a better compromise?
Redstuff are a "very fast road/trackday" pad and are a very good (and popular) all-rounder from that point of view.
Posted: Sun Jul 10, 2011 6:41 pm
by alpinab6s
check out 300mm.de for any brake set up!!! :eek:
