What's the best thing to use
cecotto479
- Caution Unreliable Seller
- Contact:
Or a plasma cutter hired for the day.
1981 E23 735i
m_jermyn
A grinder with a cutting disk mate... It's ver thin and makes perfect cuts.
When you cut it out you then offer the new metal. up to it and trim to suit.
Step one.
mark out how much metal to remove.
Step two.
Trim replacement panel close to correct size.
Step three.
Offer up replacement panel and mark wher it sits on car.
This is the only way to do it and the way we pros do it...
Mike
Step four.
Cut out rusty part on car but be sure to leave enough material to weld the new panel on.
Step five.
Clamp new metal to car using clamps or self tapers.
Step six.
Cut through the new panel and old panel close the edge of the new panel and remove the trimmed metal.
Now you will have a perfect 1mm line to fill with the welder
Step one.
Step two.
Step three.
Mike
Step four.
Step five.
Step six.
teamalsoran
i use an air hacksaw for most of my cutting and it does a nice accurate job
m_jermyn
No roblems,
Remember to drill out the spot welds and take your time withe the welding, very small stitches in different parts no more the 5pm long and let it cool right down before progressin. DO NOT USE WATER TO COOL IT. you will shrink it and distort the metal..
It's hard but be patient the job will be alot better.
Same goes for grinding, don't let it get to hot.
