HID kits - Where to buy from direct? Not Ebay.
Posted: Thu Dec 02, 2010 10:28 pm
by Dan320is
Chaps,
I'm after HID kits for both my daily E30 and the girlfriends E46 Compact.
Where is best to buy these kits from? I'd rather buy direct from a company rather than Ebay in case of any problems further down the line.
www.hids-direct.co.uk ?
www.hids4u.co.uk ?
Re: HID kits - Where to buy from direct? Not Ebay.
Posted: Thu Dec 02, 2010 10:45 pm
by B7
Steer clear of HID direct. They simply could not supply the correct holders for my e39 (and it still ain't right after 6 months) and already I've had to drive about with one H7 bulb and one HID as the ballast popped after 4 months. They are a nightmare to deal with after market. Tardy, lack of coms etc.
Look elsewhere if my experience is anything to go by!
Posted: Thu Dec 02, 2010 10:53 pm
by harry_p
i looked into this a while ago and concluded that the 'reputable' places probably sold exactly the same kits as the cheap hongkong ebay sellers, and were just as likely to vanish into thin air.
buy cheap buy twice? maybe, but when the cheap is less than half the price then you may aswell!
Posted: Thu Dec 02, 2010 11:14 pm
by dips346
i have brought from here before www.hids4u.co.uk and were fine or if you want some from a proper firm then use http://www.ca-automotive.co.uk/home.php
Posted: Fri Dec 03, 2010 2:18 am
by rp2
ive used hids4u and i was happy with the service and product
Posted: Fri Dec 03, 2010 7:18 am
by charlE30
Brought my last set through ebay at around £40 deliveried and they lasted over 5 years with plenty of use, I've now upgraded to the 55w HID variant :cool: again from ebay.
I'd put money on you getting the same kit in different packaging from the UK suppliers but will pay twice as much.
Which ever way you go it's one of the best mods going for an E30 (without retrofiting different projectors winkeye )
Posted: Fri Dec 03, 2010 9:35 am
by Morat
charlE30 wrote:Brought my last set through ebay at around £40 deliveried and they lasted over 5 years with plenty of use, I've now upgraded to the 55w HID variant :cool: again from ebay.
+1
the ebay kits are so cheap that you if you're worried about something breaking you may as well just buy two sets.
Posted: Fri Dec 03, 2010 12:31 pm
by daimlerman
I have bought and fitted two kits selected at random from fleabay(ie,the cheapest!)both fitted without problems and are still working fine,one has been fitted for almost two years.
Posted: Fri Dec 03, 2010 2:47 pm
by Razorsharp
I bought a set of 35w 4300k HID's for my old E46 (sorry) from here:
http://www.rclick.co.uk/product_info.ph ... cts_id=812
They were a good product and delivered the next day.
My touring is currently fitted with a £35 set from fleabay which work perfectly and I've had no problems since fitting, even in the cold weather
Re:
Posted: Fri Dec 03, 2010 2:54 pm
by Mikey_Boy
+1 for HIDS4U...! :thumb:
Bought 3 kits from these guys so far - when I had a problem with one of the ballasts on my E30, they replaced that without any fuss at all.
Fast dispatch, good price, easy to install and great support after.
Cheers,
Mikey_Boy
Re:
Posted: Fri Dec 03, 2010 4:03 pm
by James90
A mate of mine bought a set for a new focus from autotronics, they looked really good quality and have been fitted for a year and have given no troubles.
Re:
Posted: Fri Dec 03, 2010 6:42 pm
by dannyb0y
got mine from HIDS4U spot on dan! only thing that bugs me with hids on the e30 (well mine at least lol) is that you cant really have the side lights on anymore as they either flash like crazy! or if you disconnect the resistor in the ns inner wing as suggested in other threads, the side lights work but brings the check light on (unless ive done something wrong lol)
but like i say hids4u spot on for me, ive had a cheap set as well in the past which kept draining the battery for some reason?? but that was a few years back tbh
Posted: Fri Dec 03, 2010 6:54 pm
by Kos
dips346 wrote:i have brought from here before www.hids4u.co.uk and were fine or if you want some from a proper firm then use http://www.ca-automotive.co.uk/home.php
same here
