What i've already got - the problem is with glue after vinyl stripping - you should remove it completely, and priming
Also, this quote from r3vlimited:
...huge amount of prep work is required to do the proper job, the hardtop is made of some funky material that requires special primer and bondo compounds, not just the regular stuff that you use for the car, it's sort of a mix between the marine and automotive. I've primered my top twice to get rid of all the imprefections, huge work ....
http://www.r3vlimited.com/board/showthread.php?t=117987
Any info would be appreciated
