induction kit on 318i---worth it?
e30mtec
Fri Sep 10, 2010 11:21 pm
is it worth putting an induction kit on a 318i or just stick with performance panel filter?
iceox
Fri Sep 10, 2010 11:28 pm
no and no, stick with standard
Bristol_Jer
Fri Sep 10, 2010 11:38 pm
You should get a bit more induction roar if that is what you're after, but not much, if any, power increase
GrindCulture
Fri Sep 10, 2010 11:40 pm
Bristol_Jer wrote:You should get a bit more induction roar if that is what you're after, but not much, if any, power increase
The opposite in my experience. Every car I've driven with an induction kit has had piss poor throttle response and was really lethargic low down in the revs.
Not in E30s any more :(
e30mtec
Fri Sep 10, 2010 11:47 pm
ill just get an oem replacement then..was just askin as its bein serviced tommorow ..thanks guys
