spark plugs
Posted: Fri Sep 03, 2010 5:30 pm
by austin360
can anyone tel me the number of NGK plugs for my M20 2.5 engine
Posted: Fri Sep 03, 2010 5:52 pm
by Scott72
In the US it is NGK ZGR5A. Probably the same on you side of the pond.
Re:
Posted: Fri Sep 03, 2010 6:09 pm
by penton08
I have seen ZGR5A's fitted to m20 engine but BPR6ES's are what you need!!
Re:
Posted: Fri Sep 03, 2010 6:28 pm
by HJG-E30
I went to get some BPR6ES plugs today but my local motor factor didn't stock them, and only had Bosch. I didn't get them as i've heard nobody seems to like using Bosch plugs. Why is this ? BMW used Bosch plugs from factory...
Re:
Posted: Fri Sep 03, 2010 6:34 pm
by e30-EVN
bosch plugs are shite, they last nowhere near as long as ngk r's. ive always used ngk plugs in all my cars and cars that i have serviced for peolple... ngk bpr6es are the best plugs to use on a b25
Re:
Posted: Fri Sep 03, 2010 7:01 pm
by BEERBOY123
I hate Bosch plugs too, NGK much, much better in my opinion. I don't know why BM used Bosch (in some E30 engines) but then I guess Bosch were/are on the books for all sorts of other electrical bits (lights, AFMs, all the rest) and so they got the sparks contract.
Re:
Posted: Fri Sep 03, 2010 7:14 pm
by rossmc88
whats the difference between ZGR5A's and BPR6ES's? Ive fitted ZGR5A's, but now I'm worried I've fitted the wrong ones :(
Re:
Posted: Fri Sep 03, 2010 7:15 pm
by penton08
bosch are not great, but at least they work!! anybody tryed the cheapo denso shite ecp sell? NGK ftw!!!
Posted: Fri Sep 03, 2010 7:47 pm
by mikey75
I'm looking at changing the plugs on my 325i this weekend, went on the NGK website and it says use ZGR5A but on here it's saying BPR6ES, now I'm confused!!!
Posted: Fri Sep 03, 2010 8:47 pm
by Scott72
In the US guys seem to run BPR6ES if you have a decent CR because its a colder plug than stock other wise ZGR5A (stock) which is a comparable plug to the old Bosch Supers. Being you guys are blessed with higher CR then the 8.8:1 we get in the I's over here I'm sure BPR6ES works great. Right now I'm running ZGR5A in my Hartge H23 with 10:1 compression with no issues, but I just ordered a set of BPR6ES to see if it makes any difference.
