Bilsteins
Posted: Thu Aug 26, 2010 6:21 pm
by chopper
Hi guys, just bought a used pair of b6 rear shocks that are suppose to work very well, so should I be able to press them in with my hands and one shock takes 45secs to rise fully and the other shoots up! I've pumped the shock for 20mins and made it worse, maybe they have been laying down so need to keep upright for a day to let the gas set???. With my cheap gmax shocks I have to use my body weight to press the shock in and they rise almost at the same time but I can push the car down by an inch and half, so just wanted to know if the b6 shocks are fine or cream crackered Cheers
Re: Bilsteins
Posted: Thu Aug 26, 2010 6:57 pm
by chopper
Anyone ??
Re: Bilsteins
Posted: Thu Aug 26, 2010 8:23 pm
by chopper
BuMp
Re: Bilsteins
Posted: Thu Aug 26, 2010 9:11 pm
by octanejunkie
Hmmm.
I'd expect them to both perform the same. Its possible they might come good after being upright for a bit.
Sounds like they could be past it though..
Re: Bilsteins
Posted: Fri Aug 27, 2010 10:50 am
by chopper
Can't be only one person who has any info on this.
Re: Bilsteins
Posted: Fri Aug 27, 2010 8:43 pm
by accesspecialist
Dont know mate but I just replaced the dampers on my other car and both seemed to return at the same rate. Both took the same effort to compress which was not much. They were new out of the box but cheap pattern parts.
Hope that helps.
Re: Bilsteins
Posted: Fri Aug 27, 2010 8:49 pm
by Topblag
I'm no expert but I'd say that as long as they return themselves they're useable. Clearly they're not in great nick but as long as there's no leaks I'd use them.
Re: Bilsteins
Posted: Fri Aug 27, 2010 8:57 pm
by penton08
good ones should "spring" out to the full extension quite quickly and be fairly hard to push in by hand. one of yours sounds passed it. and they should be stored compressed, i dont think it make any difference if there stored laying down.
Re: Bilsteins
Posted: Fri Aug 27, 2010 9:00 pm
by chopper
So if I keep the slow one compressed for a day will that do anything??
Re: Bilsteins
Posted: Fri Aug 27, 2010 9:02 pm
by accesspecialist
pass
Re: Bilsteins
Posted: Sun Aug 29, 2010 9:27 am
by octanejunkie
worth a try isn't it
