Does this sound like trailing arm trouble?
Posted: Fri Aug 06, 2010 10:40 pm
by Conan
Get a weird grinding/knocking noise from the rear when i turn reasonably sharply and it was much worse yesterday when i had the boot loaded.
Does that sound like the rear trailing arms. The rear bushes are all brand new by the way
Re: Does this sound like trailing arm trouble?
Posted: Fri Aug 06, 2010 10:41 pm
by magpie
zaust play?
Posted: Fri Aug 06, 2010 10:42 pm
by Conan
definaltely suspension based.
Posted: Fri Aug 06, 2010 10:47 pm
by magpie
rear top mount?
has this just came about after a recent rear bush change?
Posted: Fri Aug 06, 2010 10:50 pm
by Conan
yep changed all the bushes and this noise started?
Posted: Sat Aug 07, 2010 12:08 am
by Dezzy
Wheel bearing???
Posted: Sat Aug 07, 2010 10:16 am
by Simon13
suspension doesn't make grinding noises when its failed they knock and cause strange handling! could be a CV joint dying
Posted: Sat Aug 07, 2010 10:56 am
by zaust
magpie wrote:zaust play?
Oi, I am short but it is not me !!!
If its a bearing you will find a bit of play in the wheel when you jack the car up. Could be a combination of exhaust knock and as Si said cv. Get it checked out properly.
Posted: Sat Aug 07, 2010 4:08 pm
by Conan
ill stick it om a ramp and have a look then
Posted: Sat Aug 07, 2010 7:42 pm
by Simon13
i would of thought jacking the back up and spining the wheels would tell alot, if its a grinding noise
Posted: Sun Aug 08, 2010 12:04 am
by Kos
is the spring located correctly ? it could be out of place and hitting the shaft.
seen this happen quite recently
Posted: Sun Aug 08, 2010 10:33 am
by ucpsale
Broken spring maybe?
Posted: Tue Aug 10, 2010 3:55 pm
by Kos
any up date ?
