Any One Know This Car
Posted: Thu Jul 29, 2010 1:31 pm
by cube320
Does any one know any thing about this car, or seen it before?
With the modifications listed will it produce 240bhp and a 10.000rpm limit. :?
I guess the only way to know would be to bit it on a dyno?
http://pistonheads.com/sales/1911545.htm
Re: Any One Know This Car
Posted: Thu Jul 29, 2010 1:50 pm
by billgatese30
Not sure how much I'd trust stock rockers at 10k revs as there is no mention of uprated ones. Not sure how the standard springs would hold up at that pace either, you may end up getting the valves starting to bounce at that speed which wouldn't be good, again, unless they have been uprated and it just doesn't mention it.
Posted: Thu Jul 29, 2010 2:03 pm
by HairyScreech
hmmm, no print out, no sale.
Posted: Thu Jul 29, 2010 2:10 pm
by e30-EVN
i dont care what exhaust system you stick on a straight 6 pot it wont sound like a v8!! v8's hav a different sorta rumble where the 6 has that...... distinctive growel. b25 is my fav engine noise jus made me laugh when i read that part. :), also 10,000rpm is v-tech teritory man, cud u really get that from this engine?? other than that tho she's very nice dude
Posted: Thu Jul 29, 2010 2:23 pm
by ross_jsy
No reason an m20 couldn't do 10k rpm as long as everything is very well balanced and strengthened. After all a straight 6 is one of the most naturally balanced engines anyway.
Pray they are uprated rockers mind 8O
Posted: Thu Jul 29, 2010 2:27 pm
by cube320
Thanks for the replies. Im interested in it but don't know much about modifiying a m20 and thought i will get opinons and questions i could ask before i ring him up.
Posted: Thu Jul 29, 2010 2:34 pm
by Ziggy
Hmmm. It'd take a bit more to convince me that it'd make 240bhp...
The price looks reasonable enough though anyway - if it's solid of course.
Posted: Thu Jul 29, 2010 3:20 pm
by octanejunkie
My Hartge H5 had strengthened/uprated rockers and springs, and that was only putting out 245hp in an M30.
If this engine has had as much spent on it as claimed, someone obviuosly knew what he was doing when he built it, and would have almost certainly uprated the top end to cope with the extra grunt.
Posted: Thu Jul 29, 2010 3:24 pm
by Fushion_Julz
Fairly sure that 240bhp would be unobtainable from the standard AFM/induction....
I know of a 2.7 M20 putting out over 250bhp, but that's on slide throttles and mechanical injection at 8500rpm...
The long stroke nature of the 2.7 crank would tend to mitigate against any menaingful gains at ultra high revs and I'd also expect upgraded springs, forged rockers and upgraded valve stems/seats for 10K, too
Posted: Thu Jul 29, 2010 4:43 pm
by djk
That ad reads like a schoolboy's wet dream. I'd doubt the truth of any of it TBH. Shame, because it's probably a pretty good car, just the owner has probably got a bit carried away with the ad and it will put a lot of people off.
Posted: Thu Jul 29, 2010 7:36 pm
by pacerpete
Forged camS, plural / Seller , Jay ,High Wycombe . Nothing else needs to be said ! avoid :eek:
Posted: Thu Jul 29, 2010 7:47 pm
by Theo
I'm sure he wouldn't mind if you tested out the 10k rev limiter on a test drive.
Posted: Thu Jul 29, 2010 8:08 pm
by HairyScreech
the stock manifold runs out at a peak of 255hp, tested myself so thats 100% fact. the manifold wont flow any more air than that.
if hes anywhere nearby i dont mind taking a look, should be able to tell bull shit in about 30 seconds flat now.
Posted: Thu Jul 29, 2010 8:27 pm
by stenni
As soon as I saw this car I knew to head over to the Zone ASAP. I'm interested also, but is it too good to be true? It is rather reasonably priced if it does what it says on the tin! winkeye
Posted: Thu Jul 29, 2010 8:47 pm
by sheebie
pacerpete wrote:Forged camS, plural / Seller , Jay ,High Wycombe . Nothing else needs to be said ! avoid :eek:
He seems to be selling alot of cars recently.....
Posted: Thu Jul 29, 2010 9:56 pm
by Alex
sounds like the seller has no clue what so ever :?
