Oh b*llocks
Posted: Fri Jul 23, 2010 4:11 pm
by tomti
my e30 has been off the road for a while sitting on my drive.
I wanted to start it up today to move it, i knew the battery was flat but thats ok i thought, the clifford alarm isn't working due to being flat but the doors open with the key.
Only thing is, the boot wont open with the key and guess where the battery is. You know, the battery i need to jump start! :x
Any ideas guys :cry:
Posted: Fri Jul 23, 2010 4:15 pm
by Simon
Open your bonnet, and use your jump leads under there, postive on the connector near the O/S front strut, and negative on the engine eyelet.
Emergency bonnet release is located behind the N/S grill, small hole in between 2 screws, stick a flat blade in there to release.
Re:
Posted: Fri Jul 23, 2010 4:22 pm
by tomti
ok mate thanks. Just one more problem. Ive just snapped the only key i have for it in the bootlock! I just thought i'd try it gently one more time and didn't hear or feel it snap but when i pulled the key out half of it is still in the bootlid barrel. FOR F*CKS SAKE! :x
Re:
Posted: Fri Jul 23, 2010 4:25 pm
by rubber_duck89
Its not your day is it? That will have to be a new lock set then maybe?
Re:
Posted: Fri Jul 23, 2010 4:26 pm
by tomti
yea i guess so. How do i open the boot now tho to remove the old lock?
Re:
Posted: Fri Jul 23, 2010 4:28 pm
by Banjo1981
If you can get the boot open using the central locking you should be able to take the barrel out of the lock and get the key out that way, any good key cutter should be able to cut you a new one from the two bits.
Re:
Posted: Fri Jul 23, 2010 4:29 pm
by Brianmoooore
tomti wrote:yea i guess so. How do i open the boot now tho to remove the old lock?
You take out the rear seat back, knock out the steel ski hatch panel, and throw a well trained small child through into the boot.
For the battery; open the bonnet and charge the battery by connecting to earth and the phantom battery + terminal on the bulkhead by the front battery tray.
Re:
Posted: Fri Jul 23, 2010 4:45 pm
by TouringTash
through the back seats as Mr Moooore says. Had to do that on a few 3 box cars and and its always all gone back togeter ok.
Though as well trained small children are in short supply I can offer the loan of an obediant Jack Russell. :wink:
Re:
Posted: Fri Jul 23, 2010 4:57 pm
by tomti
right, i hooked up a battery in the hope of being able to use the central locking but all my alarm does when you press the fob is beep and doesn't unlock anything. i thought about the ski hatch but the only problem is the massive strutbrace going across the opening :cry:
Maybe ill just keep it as a garden feature
Re:
Posted: Fri Jul 23, 2010 5:02 pm
by TouringTash
just wait and let the battery charge for a bit, turn off the interior lights and go and have a cuppa.
Re:
Posted: Fri Jul 23, 2010 5:08 pm
by tomti
ill try again tomorrow. ive given up and calming down before the petrol cutter comes out.
Thanks for the help chaps
Re:
Posted: Fri Jul 23, 2010 5:29 pm
by capri_rob
If the bootlock is fecked anyway a screwdriver in it and a good smack from a hammer is as effective as it always was at getting the boot open. Make sure you've got another lock and key to replace it with first though.
Re:
Posted: Fri Jul 23, 2010 6:23 pm
by magpie
Re:
Posted: Fri Jul 23, 2010 6:35 pm
by nickso
have you tried using the key in the lock again? if it works you can strip the lock down and retrieve the broken bit and just use a new key.
Re:
Posted: Fri Jul 23, 2010 6:40 pm
by magpie
try a magnet and a pin,......then it's hammer time and a new boot lock.
Re:
Posted: Fri Jul 23, 2010 9:36 pm
by tomti
ok turns out i have a really handy friend! He came round my house with a broken key extractor tool. he trained as a locksmith years ago. had the broken part out in minutes so im off to a locksmith tomorrow to see if i can get a key cut from both halfs. Im in a better mood now :D
Re:
Posted: Fri Jul 23, 2010 9:43 pm
by TouringTash
if it doesn't work out and I do hope it does but if the worst is going to happen I'm willing
to pay for the fuel for the petrol cutter If I can come and watch.
winkeye
Re:
Posted: Fri Jul 23, 2010 9:46 pm
by magpie
tomti wrote:ok turns out i have a really handy friend! He came round my house with a broken key extractor tool. he trained as a locksmith years ago. had the broken part out in minutes so im off to a locksmith tomorrow to see if i can get a key cut from both halfs. Im in a better mood now :D
a friend in need..... :D
