confused,which ecu?
Posted: Fri May 28, 2010 7:33 pm
by gafta
hello zoners, i bought a 325i engine last month , it came with the wiring loom but no ecu. a friend of mine tells me i have a facelift engine (not the best one) appently the engine was removed from a 325i touring. on the head theres a logo stateing 2.5 and underneith that 2.7, i hear that these heads where made in china and are common for head gasket fails or carcking heads, but i was given a reciept that states the mileage and a rebuilt engine, head gasket ect , so really should b a ok i hope :o: , now i havent got round to fireing her up just yet , but i want a ecu that i can chip and get the most out of this engine, i bought a e34 525i petrol manual ecu today, the guy that sold it to me says this will fit ok as the e34 2.5 was a m20 lump, is this all correct? the part number on the ecu is bosch 0 261 200 178. whould this ecu be ok for this engine? :eek:
Re: confused,which ecu?
Posted: Fri May 28, 2010 9:23 pm
by gafta
willnz wrote:If the ecu plug on 325 engine matches that on the e34 engine, it will work.
there's a part number on the plug on the 325 wiring loom , if it's the same as the e34 one then it should be ok??
Thatnks for your response , appreciated.
Posted: Fri May 28, 2010 9:36 pm
by gafta
willnz wrote:There are 2 types of ECU plug, one has 2 rows of pins, the other has 3 rows. The e34 would be 3 rows, if the 325 is a 3row plug, the e34 ECU will work in it.
willnz u are the man! I never new that , will give it ago, cheers very much
Posted: Fri May 28, 2010 9:43 pm
by Speedtouch
According to this list, the 178 ECU is intended for an E32 730i, but fear not, being a later Motronic 1.3 ECU from a six-pot BMW, it will work with your M20B25, provided you change to a suitable EPROM chip winkeye
http://www.bimmer-parts.ca/bmw_dme_info.htm
Posted: Fri May 28, 2010 10:25 pm
by gafta
Speedtouch wrote:According to this list, the 178 ECU is intended for an E32 730i, but fear not, being a later Motronic 1.3 ECU from a six-pot BMW, it will work with your M20B25, provided you change to a suitable EPROM chip winkeye
how much extra bhp will your chip add? Cheers
Posted: Sat May 29, 2010 12:22 am
by Ant
Nice plug Maurice :D
if your original was a 172 ECU you can chip that to suit too.
Posted: Sat May 29, 2010 6:12 am
by gafta
Ant wrote:Nice plug Maurice :D
origanal engine was a m20 b20 , ant do you have any chips for the 178 for sale? Or where can I find one ,Cheers
Posted: Sat May 29, 2010 6:39 am
by gafta
Acually I was on eBay just , and there's a 320 ecu with a 172 part number , so possibly my original ecu may b a 172 , so I wouldn't really need this 178 , where can I by a suitable chip for this 172 to run m20 b25 ??? 8O 8O
Posted: Sat May 29, 2010 12:30 pm
by Speedtouch
I can supply one, posted, for £25 - PM sent.
Posted: Sat May 29, 2010 12:50 pm
by cbv8
Speedtouch wrote:I can supply one, posted, for £25 - PM sent.
Hi Maurice,
Could you supply me a chipped ECU for my 1988 325i auto so i will gain more bhp etc :wink:
Posted: Sat May 29, 2010 1:02 pm
by Speedtouch
PM sent, Chas :)
Cheers,
