325i BHP??
Posted: Thu May 27, 2010 12:51 am
by 320stu
Ive done a search nut have come up with difrent figures??
Ive got a E-reg 1988 325i Touring anyone know what the BHP is?
Thanks Stuart
Re: 325i BHP??
Posted: Thu May 27, 2010 12:53 am
by Falkster
Im sure 171 rings bells
Re: 325i BHP??
Posted: Thu May 27, 2010 1:08 am
by e30shed
You might have a high comp engine if its an '88 - possibly 174 bhp :?:
Change the ecu to motronic 1.3 and chip it! Cheap & easy mod.
Re: 325i BHP??
Posted: Thu May 27, 2010 1:12 am
by 320stu
e30shed wrote:You might have a high comp engine if its an '88 - possibly 174 bhp :?:
O tell me more :D I like cheap and easy because Im not that great with diy on cars and am poor!! :D
Stuart
Re: 325i BHP??
Posted: Thu May 27, 2010 1:13 am
by Blitz
But dont you need to change the whole loom first.
Re: 325i BHP??
Posted: Thu May 27, 2010 1:52 am
by e30shed
No loom change required. I got a 173 ecu from an E34 525i for about £20 from ebay, and an Alpina copy chip from a Zoner for £15. Fitted them myself without really knowing what I was doing, took 20 mins. Now have a small increase in BHP,better throttle response and a higher rev limit, no brainer.
This is what you need: http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0567999301
Hope it helps!
Re: 325i BHP??
Posted: Thu May 27, 2010 6:26 am
by Felix79
171 bhp for the 325i
Re: 325i BHP??
Posted: Thu May 27, 2010 7:19 am
by Dezzy
If you still or ever had 171 your very lucky. No one can tell you what bhp your engine has. Only the dyno rollers and they arnt completely accurate.
Re: 325i BHP??
Posted: Thu May 27, 2010 7:47 am
by zaust
If it's a touring, it won't have a high comp unless it had a swap at some point. And it will already be running the later motronic, They are all supposed to be 171hp but achived in different way's....
Re: 325i BHP??
Posted: Thu May 27, 2010 8:13 am
by Felix79
Dezzy wrote:If you still or ever had 171 your very lucky. No one can tell you what bhp your engine has. Only the dyno rollers and they arnt completely accurate.
Is the bhp figure for the Fly or wheels?
Re: 325i BHP??
Posted: Thu May 27, 2010 8:40 am
by suchy
Flywheel as it's a higher figure (more consumer impressing)
Re: 325i BHP??
Posted: Thu May 27, 2010 12:48 pm
by 320stu
Hope it helps!
If I get the ECU has it got to be chiped or can I just plug it straight in?
Re: 325i BHP??
Posted: Thu May 27, 2010 1:04 pm
by daimlerman
Never seen an 'E' plate touring,I always thought that they started to import them into the UK in September '88.....
Making the oldest 'F' plate,and all were 'facelift'!
Re: 325i BHP??
Posted: Thu May 27, 2010 1:11 pm
by Bump
I've got a G touring.
Sure I have seen a J reg touring??? I might be making that up though..
Ah. sorry. Just realised the meaning of the word 'oldest'.
As you were then :mad:
Re: 325i BHP??
Posted: Thu May 27, 2010 3:14 pm
by HairyScreech
im sure my mates is on an e or f, one of the absolute first. very last of the 87 reg iirc, a white 2.5 with a very odd spec, head unit blank with tweeter pods (wired in) keep fit windows all around but abs.
Re: 325i BHP??
Posted: Thu May 27, 2010 3:19 pm
by town325i
daimlerman wrote:Never seen an 'E' plate touring,I always thought that they started to import them into the UK in September '88.....
They did come out on the late E plate the tourings there was one in the boon yard i went months ago.
Re: 325i BHP??
Posted: Thu May 27, 2010 8:26 pm
by zaust
My old one, And still on the zone some where.
Re: 325i BHP??
Posted: Fri May 28, 2010 6:53 am
by gafta
Hey ppl, I hoping to do this ecu convertion on my 325i , I have been told it's a facelift engine ( not the good one) :( , can the e34 ecu 173 fit this engine and make a diffrence by chipping it? Thanks. :eek:
Re: 325i BHP??
Posted: Fri May 28, 2010 7:38 am
by zaust
gafta wrote:Hey ppl, I hoping to do this ecu convertion on my 325i , I have been told it's a facelift engine ( not the good one) :( , can the e34 ecu 173 fit this engine and make a diffrence by chipping it? Thanks. :eek:
If your on a 073 ecu set up now and you have two fly wheel sensors at the gearbox end (by the starter) Then it is worth doing. It is a case of swapping the engine looms over along with the front pully /crank sensor, brackets ect.. If it is a 172 or 173 in there, then just get a chip off of Ant or speedtouch.
Re: 325i BHP??
Posted: Fri May 28, 2010 9:52 am
by cbv8
Hope it helps!
I would very much like to do this mod is there any specific ECU that i need to buy or can it be one off any E34 525i? my car is a 1988 E30 325i convertible auto your info very much appreciated :wink:
Re: 325i BHP??
Posted: Fri May 28, 2010 10:41 am
by gafta
cheers for your quick response, problem I'm having is I have no ecu , I bought the engine but came with no ecu :(
Re: 325i BHP??
Posted: Fri May 28, 2010 2:45 pm
by Morat
My old one E605UAX was an early one, it had the dim dip lights from the first 6 months of facelift production. Dead now :(
Re: 325i BHP??
Posted: Fri May 28, 2010 4:29 pm
by cbv8
cbv8 wrote:
e30shed wrote:
Blitz wrote: But dont you need to change the whole loom first.
Hope it helps!
Not one relpy to my question come on all you BMW experts out there :roll:
Re: 325i BHP??
Posted: Fri May 28, 2010 4:37 pm
by bmwsport
I've got an E plate Alpina C2 2.5 Touring, it was supposably the demonstrator for the dealer back in the day. Sytner have confirmed it's an original car in writing and have stated the conversion took place in sept 1988.
Re: 325i BHP??
Posted: Fri May 28, 2010 7:14 pm
by zaust
cbv8 wrote:
cbv8 wrote:
e30shed wrote: No loom change required. I got a 173 ecu from an E34 525i for about £20 from ebay, and an Alpina copy chip from a Zoner for £15. Fitted them myself without really knowing what I was doing, took 20 mins. Now have a small increase in BHP,better throttle response and a higher rev limit, no brainer.
Hope it helps!
Likley hood is that you have a late engine, Where are you crank sensor/s as this will determin what managment you need. Or no one can tell you which ecu to get. And yes if you have a later set up then a e34 525 ecu will work. But still need you to awnser or take a few pic's of the engine.
