Is it possible to get new window motors?
Posted: Mon May 24, 2010 11:25 pm
by nomadx
I have a early 2 door, both the window motors are very poor, I have stripped down and regreased everything but still no good, so would rather fit a pair of new ones if I can. Anyone know if the motors can still be had new?
Re: Is it possible to get new window motors?
Posted: Mon May 24, 2010 11:31 pm
by Royalratch
Probably but a working set used is like £20, pointless going new.
There's a million zoners who will sort you out - place an thread in the wanted section.
Posted: Mon May 24, 2010 11:34 pm
by nomadx
thing is the 2 motors i have at the mo spin freely when removed from the mech, but dont seem to have the guts to do the windows without sticking and sometimes needing help to go back up. I will have no way of knowing if they are anygood until fitting them
Posted: Tue May 25, 2010 12:12 am
by magpie
squirt washing up liquid down the guides [oem fairy type] or chain oil.
Posted: Tue May 25, 2010 7:59 am
by Royalratch
Grease everything up and check your glass and guide alignment is all good.
If you have the old style mechanisms (the S shaped rails) then ditch them for the newer version which is much more robust and one of the most reliable parts on an E30.
Posted: Tue May 25, 2010 8:05 am
by bmwsport
How easy is that mod, i thought about doing that but i read that you have to drill the door panels to align up the motor fitments as the early and later door mounting points are different?
Posted: Tue May 25, 2010 8:39 am
by Royalratch
Super easy.
You have to drill just one hole about 5mm away from san existing hole for the bottom of the window guide bracket nearest the B-Pillar. Everything else is the same.
30 mins each side.
Whilst all the guts are out, clean out the doors, clear the drainage holes and flood the door with waxoil.
Clean and grease the mechs for quiet smooth operation.
Posted: Tue May 25, 2010 9:28 am
by nomadx
So the motor asse line up on the later mech asembly itself and 3 of the other holes line up? Just the one to drill? I may go this route then, as they certainly look alot better
Posted: Tue May 25, 2010 9:44 am
by Royalratch
Everything bolts right in, you may be able to keep the original runners in (the rails the inner door seals slide into) but I would get some facelift doors complete with all the guts and swap it all over - minus the locks/central locking bits.
Posted: Tue May 25, 2010 11:55 am
by nomadx
after more of a play this morning i have the drivers side window working pretty nicely, still a bit of judder right at the bottom but ok. Passenger side I think if I get a good strong motor i can have it working ok too.
Posted: Tue May 25, 2010 1:34 pm
by magpie
i have window mechs/motors for sale from early 's' type ones and newer facelift ones if you get stuck.
