urgent lsd help needed
Posted: Sun May 02, 2010 10:10 pm
by podi
hey guys need some help my m8 has a 1990 325i sport he was running a 4.10 small case welded diff and has bought a S3.91 LSD out of a 325i it is quite larger then the 4.10 but it wont fit.
when trying to fit it the drive shaft cups will line up and fit but the 4 main bolts wont line up at all has any one come across this problem before is there any way to get it to fit...
Re: urgent lsd help needed
Posted: Sun May 02, 2010 10:13 pm
by jbh
TBH there a pain in the ar*e to fit.. firstly are you sure its been removed from an E30? any pictures? have yous sat both diffs side by side to see if the holes are in the same place? could it just be a case of needing to muck around a bit more with it..
Posted: Sun May 02, 2010 10:15 pm
by e30topless
the 4 19mm bolts are a real pain to get in , make sure he 'starts ' the 2 very top bolts first !
I have found this way to be the best,
Posted: Sun May 02, 2010 10:31 pm
by bss325i
Dont tighten any of the bolts untill all four have been wound in a few threads.
Posted: Sun May 02, 2010 10:34 pm
by austin360
wel lads tha fella says he ligned 2 bolts in the prop first but the very top the holes are a little bit out of line the diff came outta sport he bought it a while ago is ther any other way of tellin it came outta a sport i took a pictre on my camera but have mis layed my lead so will put up as soon as i can
Posted: Mon May 03, 2010 12:15 am
by gareth
if he's changing from a small case diff to a medium case diff, the prop length will need to be adjusted to suit. there's a large 'nut' halfway down the prop, loosen this and it slides in and out.
push it all the way in, fit the diff then slide it back, bolt up to the diff, then tighten the length adjuster thingymajig.
Posted: Mon May 03, 2010 12:46 am
by jbh
gareth wrote:if he's changing from a small case diff to a medium case diff, the prop length will need to be adjusted to suit. there's a large 'nut' halfway down the prop, loosen this and it slides in and out.
I never even gave that a thought.. boy is changing from a 4.10 to a 3.64 so theres a good chance that is the problem
Posted: Mon May 03, 2010 12:48 am
by gareth
pay attention at the back
Posted: Mon May 03, 2010 12:49 am
by jbh
gareth wrote:my m8 has a 1990 325i sport he was running a 4.10 small case welded diff and has bought a S3.91 LSD out of a 325i it is quite larger then the 4.10 but it wont fit.
at least im not the only one..
Re:
Posted: Mon May 03, 2010 12:51 am
by gareth
oh the other thing to add regarding swapping small to medium case:
the diff output flanges are different - you need to get the flanges with the new diff and fit the lot complete.
