Lidl's JAck
Posted: Tue Feb 23, 2010 4:27 pm
by e30318ilover
http://www.lidl.co.uk/cps/rde/xchg/lidl ... x_8401.htm
would this lift a 318IS high enough?
Is it good enough
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 4:34 pm
by Ziggy
High enough for what?
Expect it's pretty much the same as all cheap trolley jacks, just with a different name on it.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 5:33 pm
by town325i
I wouldn't use a cheap small trolley jack they have a tendency to tip over when lifted to there maximum height which is just about high enough to get a wheel off.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 5:45 pm
by magpie
good enough for changing a wheel,that's about it.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 6:22 pm
by mattsbmw
With the cheap jack i had it wouldnt lift the car high enough to get an axle stand under it
So i had one of these as a birthday pressie
http://www.halfords.com/webapp/wcs/stor ... yId_165727
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 6:29 pm
by madaboutthe30
I would go all out on a jack. Its a critical tool.
What if your stuck one day in the middle of nowhere and need to change a wheel and it wont jack high enough?
Or even worst what if youve jacked it up one day and the jack gives way while your underneath?
A jack is the one thing you cant skimp out on
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 6:34 pm
by e30318ilover
madaboutthe30 wrote:I would go all out on a jack. Its a critical tool.
1.Why would i not be carrying my essential BMW jack.
2. why would i not be using axel stands as safety is critical.
All i want it for is to lift onto axel stands
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 6:36 pm
by e30318ilover
I may just wait until i can buy the halfords 5 piece kit
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 6:40 pm
by Topblag
I've got one of those Lidl jacks, and the axle stands. I've used them a lot and had no probs. IIRC they come with a 2 year warranty.
If you want a heavier duty one, Halfrauds are selling a 4x4 jack that lifts to 52cms, I got one at Crimbo and it's cracking for the money (reduced from 75 to 35). If your E30's lowered more than 60mm it won't go under the sill though !
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 10:08 pm
by DHFiS
If there is anyone near Cambridge who wants one of these I have one I will give it to you for free.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 11:12 pm
by Jozi
Just out of interest and because someone mentioned the sills.
Where do you jack the car from? I always stick the trolley jack under the end of the chasis legs. Have to drive on a piece of wood before I can get it under there but thats a different story.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 11:16 pm
by magpie
i jack from the lollypop on the front and the rear beam for one rear side or diff if i need both rears up but i prefer ramps for the later.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 11:18 pm
by Jozi
Dad made up a ramp but I can't drive up it cause the valance hits it
I'd be afraid of the jack slipping from the lolli pop but i have considered it a few times
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 11:23 pm
by magpie
the cup on the trolly jack wont allow it to slip.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 11:32 pm
by Rodderz
I have a Lidl jack and it works perfecty fine!
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 11:38 pm
by Felix79
Just remember to put a block of wood betweem the jac head and the part your jacking. Not only does it help protect but if you start hearing cracking on the wood you know to get out of the way. This technquie almost certianly saved my dads legs when I was really joung when his Damiler VP doubler 6 toppled over. He just got out in time! If your going to be lifting high enough for it to go on stands I would want good quality parts.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 11:39 pm
by magpie
i have one from netto cost a tenna and came in carry case.
very handy little number.
i have a real Jack for big stuff.
Re: Lidl's JAck
Posted: Tue Feb 23, 2010 11:40 pm
by grantfk10
Topblag wrote:I've got one of those Lidl jacks, and the axle stands. I've used them a lot and had no probs. IIRC they come with a 2 year warranty.
Description:
Made from robust steel
Lifting range approx. (cm): 13.5 - 34.2
180ยบ swivelling handle
3 year manufacturer's warranty
Sounds ok to me!
Re: Lidl's JAck
Posted: Wed Feb 24, 2010 12:12 am
by gareth
a lot of long reach jack are lower from rest too. most trolly jack struggle to go low enough to get anywhere under a E30.
i have some wooden ramps about 3 feet long and step up to 3 inches high, and the front spoiler still catches
Re: Lidl's JAck
Posted: Wed Feb 24, 2010 12:45 am
by Felix79
When dad and I were doing bits on my exhuast system we had to take my cow plough off first to even make it
Re: Lidl's JAck
Posted: Wed Feb 24, 2010 9:22 pm
by mr_dink
I've got a very similar jack but mines from Halfords.
I jack either under the diff or under the crossmember at the front (with the other wheels chocked of course) and it just about lifts the car onto axle stands.
For lowered e30s I do need to lift it a bit with the BMW jack to get the trolley jack in!
Re: Lidl's JAck
Posted: Thu Feb 25, 2010 12:42 am
by e30318ilover
Ill be getting it tomorrow then.
Re: Lidl's JAck
Posted: Thu Feb 25, 2010 8:40 am
by DaveD
just to say that I got mine from Aldi and when I was having the wheels refurbed I had to have it on the jack for a week ...never dropped a mm ..and two lengths of 3x3 raise it enough to get the jack under
