what ratio???
Posted: Wed Dec 30, 2009 12:43 pm
by tinnaM42
how do you tell what ratio a diff is???
Re: what ratio???
Posted: Wed Dec 30, 2009 12:46 pm
by gareth
look at the tag on the diff. you will probably need some emery paper to clean it up.
Re: what ratio???
Posted: Wed Dec 30, 2009 12:48 pm
by MarkF
There should be a metal tag on the diff cover which is secured by one of the bolts. It should be stamped on there!
Re: what ratio???
Posted: Wed Dec 30, 2009 1:01 pm
by tinnaM42
wot if that is rusted to s***!
Re: what ratio???
Posted: Wed Dec 30, 2009 1:03 pm
by leeparkes
tinnaM42 wrote:wot if that is rusted to s***!
wire brush, the numbers will be under there somewhere
Re: what ratio???
Posted: Wed Dec 30, 2009 2:15 pm
by daimlerman
If the tag is MIA or unreadable you will need to use your secondary shcool maths.
Turn the input shaft one complete turn and note how many time an output shaft turns.
Then comes the hard bit....divide one into the other....
