Page 1 of 2
when you wheel spin why does it thud?
Posted: Sun Dec 27, 2009 5:38 pm
by 320ise
ive noticed that when i wheel spin in wet conditions in a strait line a get a "d d d d d d d d d" banging thuding noise is this just what bmw's do or does the noise mean there is dead bushes?
thanks sorry if this is a silly question! but ive had it on all of my e30's and 34's!
Re: when you wheel spin why does it thud?
Posted: Sun Dec 27, 2009 5:46 pm
by Alex
axel tramp ?
Posted: Sun Dec 27, 2009 5:49 pm
by CHR1S1990
as far as i know, - its the bushes. Does exaxtly the same on mine, and i know mine are rendered. In the process of refurbing a rear trailing arm now with new ones to swap straight over - you'l be able to feel the improvement too!
chris
by magpie
bushes or the exhaust knocking to come in coz it's cold outside.?
Posted: Sun Dec 27, 2009 5:50 pm
by Cook318IS
Alex wrote:axel tramp ?
i was thinking that too. always makes me chuckle a little bit too
Posted: Sun Dec 27, 2009 5:51 pm
by Alex
Cook318IS wrote:Alex wrote:axel tramp ?
Last time i had it it made my diff whine like a council bus
Posted: Sun Dec 27, 2009 5:56 pm
by 320ise
axel tramp? what does that mean?
Posted: Sun Dec 27, 2009 5:59 pm
by 320ise
also if this helps if i pull the handbrake sharp it thuds then too, could it be rear top mounts?
Posted: Sun Dec 27, 2009 6:36 pm
by E30BeemerLad
I had serious axle tramp when doing burnouts at the drag strip, especially when releasing the foot brake and allowing the car to launch forwards whilst still having the rears lit up. Every bush on my car was brand new (except the diff mount bush)
Posted: Sun Dec 27, 2009 6:38 pm
by bss325i
It is normal.
Apparently the new BMW motorsport group N rear axel bushes i have aquired eliminate this.
That remains to be seen.
Posted: Sun Dec 27, 2009 6:41 pm
by E30BeemerLad
Baz, tell me more about those group N bushes.....
Are they still rubber?
by fuzzy
the only knocking id get was the prop centre bearing banging on the transmission tunnel.
Posted: Sun Dec 27, 2009 6:42 pm
by bss325i
Yes Lee they are but the voids are much smaller and i think the rubber is a different compound.
Posted: Sun Dec 27, 2009 6:44 pm
by Bob_S
bss325i wrote:Yes Lee they are but the voids are much smaller and i think the rubber is a different compound.
part numbers this way please Baz
Posted: Sun Dec 27, 2009 6:47 pm
by DHFiS
Do E30s suffer from axle tramp? I thought it was caused by the axle twisting on a leaf sprung rear suspension set up.
Posted: Sun Dec 27, 2009 6:50 pm
by Rich_W
BSS. I guess they are just harder material.
Perhaps the "race/black" poly bushes you can get from various places are the same.
To the OP, it's basically everything under the back of the car moving around due to bush/damper wear.
Posted: Sun Dec 27, 2009 6:56 pm
by mc_hawkings24
grippy tires thats what i usually put it down to.
My mates cossy does it alot so bad the knock sensor for the fuel pump cuts in lol
Posted: Sun Dec 27, 2009 7:27 pm
by magpie
DHFiS wrote:Do E30s suffer from axle tramp? I thought it was caused by the axle twisting on a leaf sprung rear suspension set up.
re anti tramp bars
not fitted to e30's
leads this "Q" not even an M3?
Posted: Sun Dec 27, 2009 7:43 pm
by 320ise
would the rear diff mount cause this? the car in question is a 525i sport m50 e34 but i have also had it on my e30 sports but when drifting round a track i dont get it when sidewards just in a strait line, the rear beam bushes are polly (yellow) and i have just changed pitman arms and arb links, the flex disc (rubber doughnut thing) looks in good shape as are my engine and box mounts, i may change the centre bearing as that may have been over looked, other things i was thinking it could be are:
the rear top mountings, rear diff mounting bush, or the centre bearing?
just wondering what would eccentric rear arm bush ware do to the car? do they ware badly or is it somthing that never really goes wrong?
Posted: Sun Dec 27, 2009 7:56 pm
by SCOTT325SE
its the rear subframe bushes mate. mine have had it too and truth be told, i should be replacing them whilst i am off work over xmas, but i really cant be arsed.
Posted: Sun Dec 27, 2009 8:07 pm
by magpie
SCOTT325SE wrote:its the rear subframe bushes mate. mine have had it too and truth be told, i should be replacing them whilst i am off work over xmas, but i really cant be arsed.
the truth.
Posted: Sun Dec 27, 2009 8:18 pm
by 320ise
would it be that mine are polly? they are not that old afaik
Posted: Sun Dec 27, 2009 8:19 pm
by bss325i
Rich_W wrote:BSS. I guess they are just harder material.
Rich_W wrote:To the OP, it's basically everything under the back of the car moving around due to bush/damper wear.
Everything on the rear of my sport and incidently my old S50 E30 was new and both had wheel tramp.
Its not worn out bushes causing it. The "tramp" is causes by the tyre starting to grip whilst still spining causing it to hop and there fore shudder.
Posted: Sun Dec 27, 2009 8:20 pm
by bss325i
magpie wrote:SCOTT325SE wrote:its the rear subframe bushes mate. mine have had it too and truth be told, i should be replacing them whilst i am off work over xmas, but i really cant be arsed.
the truth.
Nope. See above.
Posted: Sun Dec 27, 2009 8:21 pm
by bss325i
magpie wrote:DHFiS wrote:Do E30s suffer from axle tramp? I thought it was caused by the axle twisting on a leaf sprung rear suspension set up.
re anti tramp bars
not fitted to e30's
Anti tramp bars are designed for leaf sprung rear axels.
E30's have semi trailing arm rear suspension.
Posted: Sun Dec 27, 2009 8:23 pm
by bss325i
Bob_S wrote:bss325i wrote:Yes Lee they are but the voids are much smaller and i think the rubber is a different compound.
Aint got one mukka.
I bought mine off demlot but i enquired at my dealer and he said they cant get BMW motorsport parts and if i wanted them i needed to contact them direct.
Posted: Sun Dec 27, 2009 9:03 pm
by Bob_S
oh dear. I have asked about the motorsport stuff before now and was told that it can be supplied but they don't know part numbers etc.
Posted: Sun Dec 27, 2009 9:29 pm
by magpie
bss325i wrote:magpie wrote:DHFiS wrote:Do E30s suffer from axle tramp? I thought it was caused by the axle twisting on a leaf sprung rear suspension set up.
re anti tramp bars
not fitted to e30's
i know i've had both.
anti tramp bars on an e30 would you ever?
the gerry's were good-but not all that.
Posted: Sun Dec 27, 2009 9:31 pm
by bss325i
Anti tramp bars wont fit on semi trailing arms.............
Posted: Sun Dec 27, 2009 9:34 pm
by magpie
anything is possible with fabrication i'm sure.just depends whether or not you need to elimanate the problem or your driving style at certain responses?
Posted: Sun Dec 27, 2009 9:35 pm
by DHFiS
So whatever the noise is its not axle tramp.
Posted: Sun Dec 27, 2009 9:39 pm
by magpie
DHFiS wrote:So whatever the noise is its not axle tramp.
cou;d well be? if ya arse end bushes aren't mushrooming over the mounts?
but ford did cure this for me
Posted: Sun Dec 27, 2009 9:40 pm
by bss325i
The is no need for anti tramp bars on a semi trailing arm set up as its an IRS where as, for example, an old escort has a live rear axel with half shafts and there fore not IRS.
Posted: Sun Dec 27, 2009 9:44 pm
by magpie
so why the gerry tramp?
loss of traction upon bite= mas rear bush stress the time you've spent Bunny hopping
i had this in a twin wheel luton once
Posted: Sun Dec 27, 2009 9:56 pm
by wullie325i
get some rear bush void fillers as they cut down on the movment/play in the beam.
danthe did a group buy ages ago on them.
they definetly work and cut down on the "ddddd ddddd ddddd" lol from the back end.
decent rear end bushes and void fillers is about as good as you are going to get to stop the odd noises even a good e30 will make under use.
