Raising my suspension
Posted: Mon Dec 21, 2009 4:36 pm
by oos_ya_daddy
Hi. Anyone know of a way I can jack up the suspension on my E30. Need it raised up for extra clearance over the exhaust etc on a rally !
No one knows of a drop mount kit or anything similar ?
Re: Raising my suspension
Posted: Mon Dec 21, 2009 5:30 pm
by leeparkes
What, higher than standard
Posted: Mon Dec 21, 2009 6:04 pm
by oos_ya_daddy
Yes. :mad:
Posted: Mon Dec 21, 2009 6:12 pm
by leeparkes
Spring assisters will help raise it a bit but will also stiffen too
http://cgi.ebay.co.uk/COIL-SPRING-ASSIS ... 19b8a5787c
Posted: Mon Dec 21, 2009 10:51 pm
by Dave_M3
How would you need it higher than standard?!? they are like tractors on standard height although they are quite soft and wooly.
Must be pretty deep tram-lines your going down!
Posted: Tue Dec 22, 2009 10:23 am
by oos_ya_daddy
Thats pretty much it ! Its a 24hr indurance trial on farmers tracks and green lanes. Mostly up very steep hills. You have to be going very fast to get up most of them and underbody clearance is essential. I plate over the exhaust etc but wanted to get a bit more height if possible ? I tried spring assisters last time but they fell out during the rally ! Ill probably use them again but cable tie then in or something ?
Cheers !
Posted: Tue Dec 22, 2009 11:53 am
by bumpygt
looking for something like this. MCC exeter and landsend trial .
318 supercharged
i do the same with my old man in a MGBlooing at GT and it is great fun.
Posted: Tue Dec 22, 2009 12:02 pm
by Morat
iX springs? I thought they were even higher than stock.
Posted: Tue Dec 22, 2009 12:04 pm
by maxfield
Why not go to Faulkner and get custom springs made? I'm sure they're not massively expensive.
http://www.dfaulknersprings.com/
Posted: Tue Dec 22, 2009 12:26 pm
by pnd
wasn't a guy on here selling rally springs this week? i would give him a pm in the for sale section.
Posted: Tue Dec 22, 2009 12:46 pm
by alan1272
my road rally car on standard 318is springs is too low as the sump hangs quite low and even though the guard is less than a fingers width off it it only gives about 6 inches of ground clearance, which makes for a bumpy ride down the whites :cry:
can e34/e28 5 series springs be fitted i wonder?
Posted: Tue Dec 22, 2009 12:50 pm
by harry_p
how much have you got to spend?
i'm sure gaz would be able to custom make some coilovers with longer dampers and longer softer springs than usual.
at the rear you could probably get some spacers made up to sit under the standard rear springs and some custom made longer front springs
Posted: Tue Dec 22, 2009 4:42 pm
by oos_ya_daddy
Yeh thats it. I am doing the MCC Trial. Dont really wanna spend much. I normally do it in a 205gti but thought id try rear wheel drive this time. If it performs well ill keep it for other events. Ill see what I can get. Cheers for the assistance.
Posted: Tue Dec 22, 2009 4:43 pm
by oos_ya_daddy
can e34/e28 5 series springs be fitted i wonder ?
Posted: Tue Dec 22, 2009 4:55 pm
by E30star
Longer springs and longer dampers. You can get custom springs made pretty cheap from some places, had one of our customers recommend someone to me, but can't remember who for the life of me!
Rear dampers are easy - we can custom make telescopics upto 24" long. (£65+ VAT each btw)
Fronts will be tricky though, no idea where you'd get inserts with a longer piston rod...
Posted: Tue Dec 22, 2009 6:24 pm
by harry_p
Could you cut and extend the strut and put a spacer the same size under the damper? You wouldn't get any more travel as the rods would be the same length, but you would get mote clearance.
Actually couldn't you do that anyway, cut under the spring platform, extend the leg with some tube, weld it all back up and put a bung or spacer under the damper so it still sat tight to the top of the strut.
Posted: Tue Dec 22, 2009 10:22 pm
by bumpygt
oos_ya_daddy wrote:Yeh thats it. I am doing the MCC Trial. Dont really wanna spend much. I normally do it in a 205gti but thought id try rear wheel drive this time. If it performs well ill keep it for other events. Ill see what I can get. Cheers for the assistance.
a e30 on standard springs has got to be better than the snake oh i mean MG
what engine are you using?
Posted: Wed Dec 23, 2009 12:03 am
by baptie0
What if you extended the strut mounting studs & made a spacer to go between the top mount and the body? this could be done front and rear to jack it up. :)
Posted: Wed Dec 23, 2009 11:52 am
by oos_ya_daddy
I think thats exactly what I will do, having had a bit of a closer look last night. A bit like the drop mount kits you can buy for 4x4s. Basically just move the whole arangement further away from the body.
Thanks guys. Love the pics !
Posted: Wed Nov 10, 2010 2:02 pm
by oos_ya_daddy
Running a 323i.
