Decat
Posted: Sun Aug 16, 2009 11:44 pm
by calpol
Does anyone know where i can get a decat for my 320i touring???
cheers
cal
Re: Decat
Posted: Mon Aug 17, 2009 7:12 pm
by calpol
ill take that as a no then
Re: Decat
Posted: Mon Aug 17, 2009 7:22 pm
by TPS
Decat?What you want to get rid of the Cat?
Re: Decat
Posted: Mon Aug 17, 2009 7:27 pm
by maxfield
Has it even got a cat on it?
Posted: Mon Aug 17, 2009 7:32 pm
by StuBeeDoo
I could be wrong, but AFAIK all UK spec. 320i tourings came de-catted as standard. Production ended April '91 and cats weren't necessary until '92.
The front silencer looks like a cat, though.
Re: Decat
by calpol
apparently it has according to carfolio.com havnt had a look underneath yet though wanna make it sound a bit better
Posted: Mon Aug 17, 2009 7:34 pm
by calpol
StuBeeDoo wrote:I could be wrong, but AFAIK all UK spec. 320i tourings came de-catted as standard. Production ended April '91 and cats weren't necessary until '92.
ok so is there anyway of replacing the front silencer?
Re: Decat
by StuBeeDoo
calpol wrote:apparently it has according to carfolio.com havnt had a look underneath yet though wanna make it sound a bit better
They're probably making an assumption on BMW's description "cat prepared".
Re: Decat
Posted: Mon Aug 17, 2009 7:35 pm
by calpol
well it says catalytic convertor: Yes
Posted: Mon Aug 17, 2009 7:37 pm
by StuBeeDoo
calpol wrote:ok so is there anyway of replacing the front silencer?
Are you wanting to make your car more noisey?
BMW silencers are known for being efficient from a flow point of view. If you want to lose the silencer in a search for power, you're wasting your time.
Re: Decat
Posted: Mon Aug 17, 2009 7:40 pm
by StuBeeDoo
calpol wrote:well it says catalytic convertor: Yes
OK, if you look under the bonnet or under the car, can you see a lambda sensor anywhere in the front pipes?
No sensor, no catalyst.
Posted: Mon Aug 17, 2009 7:43 pm
by calpol
wanting more noise for now will worry about power when i put the 2.5 in it
Re: Decat
Posted: Mon Aug 17, 2009 7:44 pm
by StuBeeDoo
Failing that, go to your local BMW dealer, tell them the last 7 characters of the VIN code (chassis number) and ask them for a "vehicle specification enquiry" print-out. That will tell you exactly how the car came from the factory.
Mine says
200 * Delete Catalysor
200 is the factory option code.
Re: Decat
Posted: Mon Aug 17, 2009 7:46 pm
by TPS
Providing your 320I doesn't have to have one by law, then you can just put a middle box instead of a CAT, My '91 Touring has a CAT, but its not an MOT requirement
Posted: Tue Jul 20, 2010 9:08 pm
by Sweety
Does that mean my 318IS has 3 silencers then?
Re:
Posted: Tue Jul 20, 2010 9:48 pm
by JWaller360
Yep sweety, the iS has three silencers. Overkill no? :mad:
Re:
Posted: Wed Jul 21, 2010 12:24 pm
by Sweety
Yes, they aren't very good silencers then, car sounds the nuts with a standard system :)
