Page 1 of 2
Drifting problem
Posted: Tue Jul 21, 2009 9:59 am
by classictwiggy
My 316i just wont slide in the wet- on oil its fine but wont even drift an inch in the wet. It gets me down :(
Any suggestions or others with similar aggravations lol
PS the car runs great so no problems there.
Re: Drifting problem
Posted: Tue Jul 21, 2009 10:08 am
by m_jermyn
bigger motor mate I think.... or skinny tyres
Posted: Tue Jul 21, 2009 10:12 am
by classictwiggy
I think youre right- without thrashing the clutch and revving the bollocks off it now joy is to be found :(
Posted: Tue Jul 21, 2009 10:14 am
by georgen
Bigger engine and a slipper ftw !!
Even just fitting a LSD will help tbh..
Posted: Tue Jul 21, 2009 10:19 am
by classictwiggy
Aw well, i'll just enjoy cruising in it as it needs to get me to work and back for ten weeks and maybe acquire a second car to 'play' with.
Posted: Tue Jul 21, 2009 10:23 am
by Leemc2009
bigger, more powerful motor..
my 325i auto touring will slide in the wet (private tarmac) but not in the dry.. need a clutch for that.
Posted: Tue Jul 21, 2009 10:50 am
by Brianmoooore
classictwiggy wrote:My 316i just wont slide in the wet- .
Which is generally what manufacturers' try to design into their suspension! Another BMW engineering success.
Posted: Tue Jul 21, 2009 10:54 am
by Cypriotgeeza
makes me laugh the way this is the EXACT opposite of my iS!!
a bit of water on the road and a sharpish bend and bye bye back end 8O lol
good luck in your quest for sideways action mate :thumb:
Posted: Tue Jul 21, 2009 11:56 am
by Leemc2009
Cypriotgeeza wrote:makes me laugh the way this is the EXACT opposite of my iS!!
How do you drive? If doesnt just oversteer unless you plant the throttle mid corner..
BMW's handle very well - ultimate driving machine.. :cool:
Posted: Tue Jul 21, 2009 12:07 pm
by Nay
My mate has some big 17" wheels with quite a considerable amount of grip in his 316i. Its hard enough to wheelspin full stop, let alone go sideways!
TBH though, the 316i is a reasonable little car and will corner better than pretty much any stock hatchback that younger lads can get insured in or afford. Only some modern sporty hatches will be able to take the corners as well. But anyday, RWD FTW!
Posted: Tue Jul 21, 2009 2:24 pm
by Brianmoooore
Leemc2009 wrote:BMW's handle very well - ultimate driving machine.. :cool:
Assuming the suspension is in reasonable order, with decent bushes fitted - not the original twenty year old ones, and doesn't have a "60mm drop"!
Posted: Tue Jul 21, 2009 2:45 pm
by pac1982
You carnt really expect a 316 to drift even if you do get the back end out it wont have anough power to carry on the drift anyways
Posted: Tue Jul 21, 2009 2:58 pm
by Bladerider
Weld the rear diff
60psi in the rear tyres, preferably no bigger than 165
Dont be gay
Simples !!!
Posted: Tue Jul 21, 2009 4:17 pm
by classictwiggy
Bladerider wrote:Weld the rear diff
Dont be gay
Simples !!!
This reply has made my dayyyyy brighter :D
Posted: Tue Jul 21, 2009 4:23 pm
by Alex
i have cheap tyres on my IS and can go sideways out of every junction just by tapping the throttle a tiny bit, even works at low revs in second, the tyres are great in the dry but in the wet there appauling :eek:
Posted: Tue Jul 21, 2009 4:31 pm
by Jon_Bmw
NayC wrote: TBH though, the 316i is a reasonable little car and will corner better than pretty much any stock hatchback that younger lads can get insured in or afford.
Righto! 8O
Posted: Tue Jul 21, 2009 4:35 pm
by Alex
Righto! 8O
i agree with jon
my 1.0 12v corsa handled way better around town and smaller streets/roads than my IS
although once over 40mph the IS is better
Posted: Tue Jul 21, 2009 4:45 pm
by Jon_Bmw
I have to be honest a 1.0litre corsa wasn't topping my list of good handling hatchbacks. :o
Posted: Tue Jul 21, 2009 4:46 pm
by Nay
Alex wrote:
Righto! 8O
i agree with jon
Uprate the rack and lower by 30mm/40mm on reasonable suspension and your sorted. A corsa only handles better in town because of the shorter lock-to-lock ratio. Lower that and your sorted.... apart from trying to parrallel park in tight spaces :?
Posted: Tue Jul 21, 2009 4:51 pm
by Bladerider
A fairly cheapo rwd car designed in the 70's is not about to win a nimbleness competition with a similarly cheap fwd car (that actually costs less to manufacture - hence its price) thats been designed in the last 5 years !!!
Round a track with a ton of mods is a different question, but one which can easily last forever as mods are just dependent on budget rather than whats best !!
In general RWD cars offer a better performance envelope and balance, but comparing a 316 and a Saxo on handling is like comparing a kettle and a toaster at which is best at ironing !!!
:D :D
Posted: Tue Jul 21, 2009 5:17 pm
by mt1104
just need some crappy tyres on the back and a bit of persuasion... if your really brave you could even scandi flick the thing, but try at your own risk lol
Posted: Tue Jul 21, 2009 5:39 pm
by mattrs
It still should go in the wet despite the lack of grunt or a LSD. My guess is your being to gentle with the car or going to slowly.
You are going to struggle to do a true power slide, but there are many different ways to make the car go side ways or drift, more than 10 in fact and some are better suited to low power cars. Try looking on you tube for different techniques (there are several tutorial type clips). Or there is a book available called how to drift, I got mine at a shop at Brands Hatch (try googleing it).
Keep with it, its great fun and it will improve your car control once you get the knack!
Posted: Tue Jul 21, 2009 8:07 pm
by charlE30
If Tiff (last nights 5th gear) managed to get the back end of an 8 ton 180bhp double decker bus out then it'll be possible to do it in a 316. It'll be down to technique as mattrs has hinted towards.
Posted: Tue Jul 21, 2009 8:36 pm
by GrindCulture
Righto! 8O
:rofl: alright then :mad:
Posted: Tue Jul 21, 2009 9:19 pm
by DanThe
welded diff init :)
Posted: Tue Jul 21, 2009 9:53 pm
by Bladerider
To be fair, Tiff cant drift for sh1t !!!
:D :D
Posted: Tue Jul 21, 2009 9:59 pm
by d6dph
Bladerider wrote:A fairly cheapo rwd car designed in the 70's is not about to win a nimbleness competition with a similarly cheap fwd car (that actually costs less to manufacture - hence its price) thats been designed in the last 5 years !!!
:D :D
Nice to see your classic wit and humour isn't dwindling in your old age Mr G. :chuckle:
Posted: Tue Jul 21, 2009 10:15 pm
by Dezzy
200 bhp of nitro
Posted: Tue Jul 21, 2009 10:51 pm
by da4x4turbo
classictwiggy wrote:My 316i just wont slide in the wet- on oil its fine but wont even drift an inch in the wet. It gets me down :(
More speed! :twisted: :twisted: :twisted:
For the love of god more speed! :twisted:
Posted: Wed Jul 22, 2009 11:24 am
by madaboutthe30
Are you sure your doing it correctly? I never had problems with my old 316i, especially in the wet
Posted: Wed Jul 22, 2009 11:26 am
by Leemc2009
Have you been watching Fast and Furious Tokyo Drift? :roll:
Posted: Wed Jul 22, 2009 12:19 pm
by classictwiggy
lol actually yes
Posted: Thu Jul 23, 2009 1:21 am
by cool_ram_in
:D :D
we´re assuming the 316 is an e30, hence designed in the eighties...
classictwiggy, if the car is stock in the wet it should drift.
You must approach fast, brake later when you´re already on the curve and then hit the throttle and if you´re turning the wheel to the inside of the curve the rear will want to go out. When you feel the end stepping out just turn the wheel fast to the other side.
DISCLAIMER: Just don´t do it on tight areas, practice safely on large spaces or you may hurt or brake something...
ps- just youtube drift bible, the technique for ae86 1.6 is similar... low power car too...
Posted: Thu Jul 23, 2009 2:29 am
by Bladerider
Sod that !!!
Just take a longer run up, scandi flick, and use the manfoot !!!
Get down to Santa Pod DWYB days with Lex and learn good !!
If by some miracle Im there I'll happily take you out in your car and show you what I mean, although theres usually several people who will give you pointers, Lex for one !!
Hope that helps,
J.
Posted: Thu Jul 23, 2009 2:39 am
by Bladerider
cool_ram_in wrote:we´re assuming the 316 is an e30, hence designed in the eighties...
Sorry to sound pedantic, and I know Im only a noob on this forum, but given that the E30 went on sale in 1982 I suspect it was designed before they started selling them, or crash testing them, or retooled the plant to actually manufacture them, or got supporting manufacturers up to speed on parts, or got board approval for the funding and final design etc etc so I suspect they were originally conceived in the very late 70's and even if they were done in 1980 it will still effectively be based on principles from the 70's as opposed to all the experience gained from the first few months of "The 80's" lol
Again apologies if this is too difficult a concept to grasp !!
:P
