2.7 or m50
Posted: Sat Jul 04, 2009 10:57 am
by reggiebaby
as title really what difference in power is there between a 2.7 m20 .[525e] and the m50
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 11:17 am
by oguz327
The difference will depend on the budget you have for a 2.7 build.
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 11:41 am
by e30bmlover
m52....
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 12:10 pm
by hammoj28
M50 or M52 definately. I wouldn't even think about it. 24v e30's are immense.
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 12:19 pm
by Mayze
IMO if your putting the time and effort into building a 2.7 then you might as well do it properly and re build the engine from the ground up which is where that would be time consuming and costly. but when you've built it it will drop strait in with just a change of chip.
Where as the M50/52 you have no need to spend money on building the engine but you do need to spend the time and money getting it in the car and running.
I'm building a 2.7 but only because I have experience building engines but none whatsoever when it comes to putting a different engine in a car. Also the m20 donk is not the prettiest engine in the world but I looks like it belongs. I know that if I put an m50 in my car I do not have the skills to get it to look factory and being anal about these things that would bother me.
More on topic as I kind of guessed that you are weighing up the options with a fresh engine rebuilt using oem parts running a stock eta crank, high comp pistons, fast road cam, mild head work and shiny manifold i would be hoping for somewhere just under 200 bhp. I don't have a big budjet but I'm not going to scrimp on parts and I'm not in a rush so if it takes me two years to finish it so be it.
Re: 2.7 or m50
by Rickz
Whats the likely bhp from a M50 and a M52 in a e30?? (roughly)
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 12:26 pm
by DanThe
Standard M52 with the M50 manifold made 209BHP and 204LbFt or thereabouts in my old 4 door
With a decent chip and running correctly an m50 should be around 200BHP and 180ish LbFt
I wont bother posting up the results of my old M50 as the bromsgrove bunch that dyno'd it just cant be trusted
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 12:33 pm
by Jhonno
24v end of..
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 12:50 pm
by Rickz
The M52 seems like a good conversion, how expensive would it be to have the m52 in?
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 1:00 pm
by Hyperion
hi
I live in South Africa. i had my mind made up a while ago that if my current engine gave up the ghost i would be headed in the M50/52 direction.
But after looking into it i realised that i would loose my Aircon, if i went for this swap, plus the headache of getting the car registered with the new engine, issues with insurance, it would be a pain in the ass.
My vote is for the 2.7 conversion.
On another point, the power gains you can get from the m50/52 conversion cannot be ignored. If that is you ultimate goal.
regards
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 8:55 pm
by DanThe
No reason to lose the air con, all my 24v engines have ran E30 air con. Only the smaller compressor fitted to later E36's will fit though.
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 9:55 pm
by zaust
Why swap a 2.5 for a heavy 2.5 ....
2.7 / 2.8 properly or m30
Re: 2.7 or m50
Posted: Sat Jul 04, 2009 10:13 pm
by daimlerman
I have a 2.7 M20 in my 4 door.(when the cabbie is back from the bodyshop the engine will find a new home!)
I have an M50 in my touring.....
Difficult to say which I prefer,M20 pulls from tick-over,M50 goes like a cat on speed above 3500rpm,both will return mid 30's mpg driven erm, with a light foot.
The expession on the face of the driver of a current 545i when passed by an E30 is priceless!
I expect that servicing expense on the M50 will be lower(no tappets to fiddle with)but the howl as the M20 spools up to 5000rpm is priceless.
Snag is,a s/h M50 can be bought attached to a life expired E34 for £250-£350,a 2.7 will cost at least £1500 to build....
You pays your money and makes a choice,both are right and fun to drive. :D
Posted: Sun Jul 05, 2009 10:46 am
by StuBeeDoo
For originallity, "plug & play-ness" and mid-range power, M20B27.
If you don't mind tinkering on and you want a 200bhp screamer, then you want the M5x.
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 10:55 am
by 12345kevin
zaust wrote:Why swap a 2.5 for a heavy 2.5 ....
Exactly, so do it properley and use an M52, 220bhp with the right manifolds etc :D Weighs less than the old iron blocks !
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 11:53 am
by DanThe
Have you had yours dyno'd Kevin?
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 5:05 pm
by 12345kevin
DanThe wrote:Have you had yours dyno'd Kevin?
Yep, 220, exactly as Ant anticipated :D Had only done about 2000 miles when it was dynoed, so still a bit tight, much better now.
Going to get the exhaust finished and remove the standard 325 center section for a better flowing one after the summer, so hopefully a small improvement.
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 5:19 pm
by Nay
I like the idea of a proper 2.7/2.8 build. But the M20 engine is why I like E30s!
Your money mate, but tbh the 2.7/2.8 rebuilds should be done as a rebuild or the work will be a tad pointless. If you go that way do everything there is to do that you can afford for the full benefits!
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 6:33 pm
by DanThe
Is yours on M52 or M50 non vanos management and has the rev limit been raised? I need to get mine live mapped to get the best from it as its still making power at the limiter, wouldnt want to take it above 7000rpm but 500 revs makes a lot of difference winkeye
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 7:49 pm
by Bob_S
out of a 2.7, m50 and m52..
I am running an m52 now and personally think it's the best of the lot.
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 7:56 pm
by Ant
@ Dan, Kevin's is on M50 non Vanos ECU , 403 iirc
most 413 and onwards with EWS need to be mapped down the diagnostic socket.
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 7:57 pm
by Benho
m52.
Re: 2.7 or m50
Posted: Sun Jul 05, 2009 9:02 pm
by DanThe
Ant wrote: most 413 and onwards with EWS need to be mapped down the diagnostic socket.
Is this map flashing a realistic way of doing the job properly or will I need a tuning module?
