obc gong
Posted: Sun Jun 21, 2009 4:47 pm
by paulisa
just had the under dash trim out of the wifes 320 and it has a obc gong fitted and wired up thing is the car doesnt have a obc it does have aircon and cruise but no obc not even the button on the stalk so why should it have the gong my car has no cruise or aircon but it does have obc but no gong altho the wire is there should i pinch it out of her car or is it needed for something else
Re: obc gong
Posted: Sun Jun 21, 2009 5:28 pm
by Jesus325iTouring
My Touring has a gong fitted and wired up but no OBC,the original owner probably would have had to pay handsomely to have it "working".
If I were you I 'd be taking it out and fitting up to your car seeing as you have an OBC.
Re: obc gong
Posted: Sun Jun 21, 2009 6:21 pm
by bss325i
Do you have a didgital clock and outside temp gauge?
Re: obc gong
Posted: Sun Jun 21, 2009 6:22 pm
by magpie
steal it
Re: obc gong
Posted: Sun Jun 21, 2009 7:47 pm
by paulisa
hi yes it has a digi clock and outside temp gauge does this mean it is a ice warning gong on the wifes .wonder why mine aint got one it aint got a outside temp sensor either it just reads -70f or something
Re: obc gong
Posted: Sun Jun 21, 2009 10:27 pm
by bss325i
paulisa wrote:hi yes it has a digi clock and outside temp gauge does this mean it is a ice warning gong on the wifes .wonder why mine aint got one it aint got a outside temp sensor either it just reads -70f or something
If it has a digital clock and outside temp then this is known as a "6 button OBC" and has a gong that sounds when the temp drops below 3 degrees.
Re: obc gong
Posted: Sun Jun 21, 2009 10:51 pm
by paulisa
so that mystery is now solved wifes car has a 6 button obc can this be easily swapped for a 13 button like mine will it just plug in and work or is there a lot more to it.
thanks Paul
Re: obc gong
Posted: Sun Jun 21, 2009 10:53 pm
by Alex
paulisa wrote:so that mystery is now solved wifes car has a 6 button obc can this be easily swapped for a 13 button like mine will it just plug in and work or is there a lot more to it.
thanks Paul
more or less as long as you get one with the full loom its just a case of connecting it all up paul
Re: obc gong
Posted: Sun Jun 21, 2009 10:55 pm
by bss325i
There is more to it.
You will need the 13 button OBC unit, the correct wiring loom, the relay box, the stalk and the horn.
Re: obc gong
Posted: Sun Jun 21, 2009 10:59 pm
by Alex
bss325i wrote:There is more to it.
the relay box and horn is only for the immobiliser function though if you want it, something i cannot get to work in mine for some reason, must have missed something out somewhere
Re: obc gong
Posted: Sun Jun 21, 2009 11:01 pm
by bss325i
Alex wrote:bss325i wrote:There is more to it.
I'm pretty sure there is a bridged loop in main wiring loom, remove this and the immobiliser will work.
Re: obc gong
Posted: Sun Jun 21, 2009 11:08 pm
by SPADGE
bss325i wrote:Alex wrote:bss325i wrote:There is more to it.
You will need to remove the bridged loop and plug in the green/green red plug on the obc loom in place of it.
Re: obc gong
Posted: Sun Jun 21, 2009 11:12 pm
by Alex
cheers, will have a look over the week
Re: obc gong
Posted: Sun Jun 21, 2009 11:22 pm
by SPADGE
Alex if your car won't start after doing the above due to a problem somewhere in the obc etc...just replace the bridged wire plug.
Re: obc gong
Posted: Sun Jun 21, 2009 11:29 pm
by Alex
cool thats spadge
