chip install
Posted: Tue May 19, 2009 9:02 pm
by chrisE318is
im about to put a chip in my car. just wondered if i need to do anything when i start up for the first time. i.e raised idle, specific things to do upon test drive etc
Re: chip install
Posted: Tue May 19, 2009 9:07 pm
by Kemlo
It'll run rough for a bit, just steady away until it sorts itself out. Took about 30 mins for mine to settle down iirc. 325 switchable auto with a mild chip.
Re: chip install
Posted: Tue May 19, 2009 10:06 pm
by DHFiS
Who is your chip from and is it in a 318iS?
Re: chip install
Posted: Tue May 19, 2009 10:12 pm
by mhuk
Kemlo,
Notice much after the install?
I still to install my speedtouch chip.
marts
Re: chip install
Posted: Tue May 19, 2009 11:17 pm
by magpie
don't get any static charge on it.
Re: chip install
Posted: Tue May 19, 2009 11:57 pm
by Kemlo
mhuk - not a great deal of performance difference, it revs a bit higher under load and it's smoothed out the power delivery which was what I was after.
It's not a speedtouch chip though (he didn't have one for my ecu at the time - I have heard good things about them however) - got it from Ebay - quite cheap so pretty happy with it.
Re: chip install
Posted: Wed May 20, 2009 6:14 pm
by chrisE318is
looking at a few at the min want one with a good performance increase and yes its for a 318is.
magpie ive read a few posts and i no youve got one, did it give you good gains and where did you get it from?
Re: chip install
Posted: Wed May 20, 2009 7:02 pm
by DHFiS
Mines got the Evolve chip which was only £50 but might be more now. It feels like it makes a small difference to power and it removes the rev limiter.
Re: chip install
Posted: Wed May 20, 2009 7:09 pm
by Speedtouch
Chris, follow the E30 Zone Wiki Chip Fitting Guide advice, i.e., let it idle for at least 10 minutes on installation, then switch off, prior to going for a drive - this ensures that the base idle settings are learnt.
Re: chip install
Posted: Wed May 20, 2009 8:39 pm
by Alex
chip is easy to fit, opening the ecu is a pain in the arse
ive chipped mine and it made a big noticable difference, no rev limit, drives better in the lower revs, quicker accelaration well worth it on an IS
where did you get yours from ?
Re: chip install
Posted: Wed May 20, 2009 8:55 pm
by bdx
What chip are you running?
Re: chip install
Posted: Wed May 20, 2009 8:57 pm
by Alex
Re: chip install
Posted: Wed May 20, 2009 9:05 pm
by bdx
What mileage have you covered since chipping, is their a severe drop in mpg (probably hard to judge) and any engine problems.
18-20bhp seems quite a lot
Re: chip install
Posted: Wed May 20, 2009 9:10 pm
by djk
18-20bhp
Riiiiiiiight-o.
Re: chip install
Posted: Wed May 20, 2009 9:11 pm
by Alex
bdx wrote:What mileage have you covered since chipping, is their a severe drop in mpg (probably hard to judge) and any engine problems.
18-20 bhp could be throught the rev range but i doubt it, they all exagerate on ebay, although the chip works really well
had it running with the chip for at least 6-7 weeks now, much better than standard, seemed to give better low down torque too
i would deffinitly buy another
Re: chip install
Posted: Wed May 20, 2009 9:13 pm
by Alex
i was going to do a before and after run on the dyno but i thought it was not worth the hastle, prehaps i will get it done as is next time it gets serviced
Re: chip install
Posted: Thu May 21, 2009 10:09 pm
by chrisE318is
i think the chip im going to buy is the £30 off ebay. its got an ecu number on it which matches up to mine
Re: chip install
Posted: Thu May 21, 2009 10:28 pm
by Alex
chrisE318is wrote:i think the chip im going to buy is the £30 off ebay. its got an ecu number on it which matches up to mine
i would be wary with the IS ones though, i took a chance
there are 3 different firmware versions and if its the wrong firmware it will idle like a dog
Re: chip install
Posted: Thu May 21, 2009 10:56 pm
by chrisE318is
ok thanks think im guna take the chance anyway can only hope for the best. mite see a chip come up for sale soon
Re: chip install
Posted: Thu May 21, 2009 11:01 pm
by Alex
let us know how it goes, took just over a week for mine to get here
Re: chip install
Posted: Fri May 29, 2009 8:36 pm
by chrisE318is
put my chip in today not ran it much but powerwise i can feel a little increase not really given it much yet. not put it against anything yet. it runs ok. got no limiter. but runs rough at idle for around 15-30 secs when cold? is there a period for the ecu to learn the chip if so how long does it take and is the performance gains very noticeable or mild. (£30 chip off ebay)
Re: chip install
Posted: Fri May 29, 2009 9:28 pm
by djk
chrisE318is wrote:put my chip in today not ran it much but powerwise i can feel a little increase not really given it much yet. not put it against anything yet. it runs ok. got no limiter. but runs rough at idle for around 15-30 secs when cold? is there a period for the ecu to learn the chip if so how long does it take and is the performance gains very noticeable or mild. (£30 chip off ebay)
Speedtouch wrote:Chris, follow the E30 Zone Wiki Chip Fitting Guide advice, i.e., let it idle for at least 10 minutes on installation, then switch off, prior to going for a drive - this ensures that the base idle settings are learnt.
Re: chip install
Posted: Fri May 29, 2009 10:50 pm
by Alex
mine idle'd perfect as soon as i fitted mine, no rough idle at all
power was very noticable at WOT with mine, also better low down torque it would seem
Re: chip install
Posted: Sat May 30, 2009 12:08 am
by chrisE318is
i didnt do the idle start on mine is there anyway i can do this again i.e take the chip out and start again or can i do this by simply starting the car and letting it tick over?
Re: chip install
Posted: Sat May 30, 2009 12:09 am
by Alex
is yours ideling like a bag of nails ???
Re: chip install
Posted: Sat May 30, 2009 12:12 am
by Speedtouch
chrisE318is wrote:i didnt do the idle start on mine is there anyway i can do this again i.e take the chip out and start again or can i do this by simply starting the car and letting it tick over?
Disconnect the battery or ECU plug for at least half an hour to reset it, then go through the bedding-in procedure.
Re: chip install
Posted: Sat May 30, 2009 2:15 am
by chrisE318is
yep but it is alot quicker and drive ok just bad idle when cold for 15-30 seconds
Re: chip install
Posted: Mon Jun 01, 2009 9:50 pm
by chrisE318is
ok ive had my chip in over the weekend and its just got worse and worse on idle so im going to need another does anyone know who will provide the right one for my car if i give them the ecu and chip number. sure i read evolve do it but cant find a way of finding out.
Re: chip install
Posted: Tue Jun 02, 2009 12:03 am
by djk
Did you try disconnecting the ecu and leaving it to idle? Have you also tried substituting the original chip to see if the symptoms have occurred coincidentally?
Re: chip install
Posted: Tue Jun 02, 2009 8:09 am
by Speedtouch
chrisE318is wrote:ok ive had my chip in over the weekend and its just got worse and worse on idle so im going to need another does anyone know who will provide the right one for my car if i give them the ecu and chip number. sure i read evolve do it but cant find a way of finding out.
Evolve certainly used to stock them. Contact details are on their website
http://www.evolveyourcar.com/default.asp
Alternatively, try e-mailing Ant at A-Tech.
Re: chip install
Posted: Tue Jun 02, 2009 7:04 pm
by chrisE318is
djk wrote:Did you try disconnecting the ecu and leaving it to idle? Have you also tried substituting the original chip to see if the symptoms have occurred coincidentally?
yer ive tried resetting the ecu and have gone back to my original chip as it was just getting worse but its fine now so must be the chip
