Biggest wheels on an e30?
Posted: Mon Apr 20, 2009 7:34 pm
by adgie
Hi can anyone tell me whats the biggest wheels you can fit on an e30 without any trouble? I had 19s on my e36 with no problems at all but are the e30s different?
Thanks, Ash
Re: Biggest wheels on an e30?
Posted: Mon Apr 20, 2009 7:45 pm
by blingsta
ive had 18's with no probs, im sure if you go any bigger, you will need to roll the arches
Posted: Mon Apr 20, 2009 7:52 pm
by mrLEE30
18's with extreamly stiff springs i will wager!!
16's are the biggest you can go without modding the suspension, bigger than this you must stiffen the suspension or the rear will rub under compression and the fronts will rub while turning.
Posted: Mon Apr 20, 2009 7:58 pm
by Cotty
20"
Oh you ment without a lot of trouble
Posted: Mon Apr 20, 2009 9:43 pm
by blingsta
mrLEE30 wrote:18's with extreamly stiff springs i will wager!!
mine were 18's with standard shocks n springs, no issues ...
Posted: Mon Apr 20, 2009 9:55 pm
by Felix79
16" are really the best for the e30 , 17" upwards really need some work doing and/or extra care when driving.
I had 17"'s on my old cabby for a while and they were a nightmare.
Posted: Mon Apr 20, 2009 10:09 pm
by suchy
Yup 16's are the best compromise, 17's start to cause handling concerns on the road, 18+ just silly in terms of bad handling characteristics and modifications needed. You will need body and suspension modifications if lowering and wish to run 17's. Unless you don't give a crap about sh1te choppy handling and rubbing arches? Elf runs 20's on his E30 but it looks comical (in my opinion)
Hey each to his/her own though- if you want the look then go for it, it's your car
Posted: Mon Apr 20, 2009 10:29 pm
by ImysE30
I had 17's fitted, now i've got 16's, there is a lot of difference. Prefer the 16's. much better ride quality and handling
Posted: Mon Apr 20, 2009 10:31 pm
by e30topless
16" or it will drive like sheeet
Posted: Mon Apr 20, 2009 10:36 pm
by dips346
back in the day i had 19" on a 60mm drop
Posted: Mon Apr 20, 2009 11:56 pm
by blingsta
heres a picture of my old cabby with the 18's... i had no issues whatso ever with rubbing or handling !
Posted: Tue Apr 21, 2009 12:01 am
by S38B38
17" is fine ,,
but i think 18" will be to much
Posted: Tue Apr 21, 2009 12:08 am
by GrindCulture
Re:
by harry_p
is the monster truck look back in?
Re:
Posted: Tue Apr 21, 2009 1:21 am
by adit
17" alpina reps on my standard iS, no problems whatsoever
Re:
Posted: Tue Apr 21, 2009 10:55 am
by adgie
Cool cheers guys,its lowered on 17s at the mo with no trouble but I was just curios. I have seen some 16 inch borbet wheels I like on ebay, just unsure what they would look like.
Thanks, Ash.
Re:
Posted: Tue Apr 21, 2009 12:48 pm
by ImysE30
Borbet A i presume. They look very nice on E30's
Re:
Posted: Tue Apr 21, 2009 1:18 pm
by adgie
Re:
Posted: Tue Apr 21, 2009 1:59 pm
by blingsta
very nice matey
Re:
Posted: Tue Apr 21, 2009 2:17 pm
by LeonNewton
16 is max imo but 15 realy looks best.
Re:
Posted: Tue Apr 21, 2009 2:22 pm
by Jhonno
Nothing wrong with proper 17's and proper sized quality tyres..
However, I think 16's is the optimum size tbh
Re:
Posted: Tue Apr 21, 2009 4:22 pm
by harry_p
heh, that's wierd, my comment above was posted without seeing grindcultures post of a monster e30 which went up at exactly the same time
17s can look good, but is a lot harder to get right. most e30s on 17s look poop. any bigger and it'll never look right. 16s are pretty much the universal 'correct' size. the e30 is a fairly small car with shallow sides, with big wheels it tends to look like it's perched on top of them
Re:
Posted: Tue Apr 21, 2009 4:37 pm
by Jon_Bmw
The more aware on here realised what you meant I Harry. I had a little
Posted: Tue Apr 21, 2009 8:01 pm
by Cotty
GrindCulture wrote:
Funny thing is they are probably only 15" with huge tyres
Re:
Posted: Tue Apr 21, 2009 10:26 pm
by ShakeyC
Also bare in mind wheel width and tyre profiles some combinations work better than others depending on suspension setup.
Re:
Posted: Tue Apr 21, 2009 11:06 pm
by junkman
i had 17's the handling felt off got the 16's on an it was like the whole car had changed better handling.
