Is 3.25 diff ok with m50 engine and box?
- Bavarian_Autotech
probably the perfect ratio as iirc the E36 boxes have 1:1 5th
M3 is medium case yeah. Check that the alloy backplate has 8 bolts holding it to the diff casing, not 6 like the smaller type. The fill/drain plugs are directly above/below one another on the medium case diff, whereas they aren't on the smaller type.
Anything more to add on that Theo? I've just put a 4.45 small case lsd on my 325. Should I just avoid too many full bore starts?Theo325 wrote:Make sure it's a medium case type, the smaller ones can take offence to heavy launches on more powerful engines.
