				Air con - what is it worth?
				Posted: Sat Mar 14, 2009 1:23 pm
				by ROC
				Fellas, collected a charming 316i moredoor today, it has original air con system that works very well.
What is the going rate for the system please?  I seem to remember reading about different types of gas, is there a way to identify what sort it is using?
Thanks a lot,
Rich.
				Posted: Sat Mar 14, 2009 1:43 pm
				by e30cossie
				On all cars there is normaly a sticker with all the infomation. It will be r12 or r134a. If you can get a picture of the charging port I could also tell you (take the plastic cap off and get a picture).
I have a drop in replacement for r12 if that is any use ?
				Re:
				Posted: Sat Mar 14, 2009 1:47 pm
				by cypriot_boy_2k7
				around £150-£200 there has been a changeover on gas, bmw do a kit for it. any interest in selling the a/c
				Posted: Sat Mar 14, 2009 2:36 pm
				by ROC
				Thanks lads,
Bit of an odd car in some ways, the fella I got it from said it was imported from Guernsey.  The speedo is in km/h there is a proper sump guard (the thick one), one of those extra fuel tanks behind the seats, the VIN plate says made in South Africa.
				Posted: Sat Mar 14, 2009 2:45 pm
				by e30cossie
				That is a r12 port
				Re:
				Posted: Sat Mar 14, 2009 2:49 pm
				by ROC
				Thanks cossie, does that mean that it can't be re gassed when it needs it?
				Posted: Sat Mar 14, 2009 2:56 pm
				by e30cossie
				You cannot get r12 anymore and everyone will say convert it to the new r134a. I am a air conditioning engineer and have a drop in replacement for r12 .
				Posted: Sat Mar 14, 2009 3:01 pm
				by cypriot_boy_2k7
				e30cossie wrote:You cannot get r12 anymore and everyone will say convert it to the new r134a. I am a air conditioning engineer and have a drop in replacement for r12 .
how much, what do you get
				Posted: Sat Mar 14, 2009 3:19 pm
				by e30cossie
				I charge £60 to recharge the refrigerant on any car ,but it depends on where you are.
				Re:
				Posted: Sat Mar 14, 2009 3:30 pm
				by ROC
				Thanks for the help cossie, further to the sump guard etc check out this subtle accessory on the dash
				Re:
				by cypriot_boy_2k7
				oh you have a gas in replacement to the r12
				Posted: Sat Mar 14, 2009 3:48 pm
				by e30cossie
				I use 413a as a drop in replacement for r12.
				Re:
				Posted: Sat Mar 14, 2009 3:52 pm
				by cypriot_boy_2k7
				ok whats the differance in them, want to know cos im studying this at college
				Posted: Sat Mar 14, 2009 4:01 pm
				by e30cossie
				I do not know what you mean?
R12 is now illegal and can no longer buy.
R413a is legal and a recommended drop in replacement for the automotive industry.
Some garages charge r12 systems with r134a. It does work for a while but the refrigerant drags the oil from the compressor causing it to fail.
				Posted: Sat Mar 14, 2009 4:08 pm
				by cypriot_boy_2k7
ive read that quite oftern,
413a is MO49 correct?
				Posted: Sat Mar 14, 2009 4:12 pm
				by e30cossie
				I think mo49 is the same but have not used it myself. Different gas companies recommend different gases.
What are you doing at college ?
				Re:
				Posted: Sat Mar 14, 2009 4:28 pm
				by cypriot_boy_2k7
				HVAC service and maintinance
				Re:
				Posted: Sat Mar 14, 2009 4:55 pm
				by Simon13
				thats a SA built car then! RHD with knh speedo. Where sump guards and A/C where standard fit on all E30's out there
				Re:
				Posted: Sat Mar 14, 2009 5:11 pm
				by swindler
				e30 cossie are you near London?
				Re:
				Posted: Sat Mar 14, 2009 5:15 pm
				by DanThe
				Post a pic up of the sump guard, show all these alloy plate pansies what a proper sump guard looks like
				Posted: Sat Mar 14, 2009 5:19 pm
				by e30cossie
				I am in Luton and do a lot of work in London.
				Re:
				Posted: Sat Mar 14, 2009 5:29 pm
				by swindler
				When are you next here? I'm in Kennington SE11 could you top up mine (I'm assuming it hasn't been converted)
The condensor seems to click in fine
It's Manual climate control, same thing isn't it?
				Posted: Sat Mar 14, 2009 6:12 pm
				by e30cossie
				pm me a contact number
				Re:
				Posted: Sat Mar 14, 2009 6:16 pm
				by ROC
				Re:
				Posted: Sat Mar 14, 2009 6:20 pm
				by jamie323i
				ROC wrote:Thanks for the help cossie, further to the sump guard etc check out this subtle accessory on the dash
Do you reckon it could of been a taxi?
Thats the sort of thing they would have fitted,not very subtle though!
				Re:
				Posted: Sat Mar 14, 2009 6:40 pm
				by DanThe
They are good, ive bounced mine off bricks and uneven road at speed when the suspensions been loaded up, alloy plate would just disintegrate in comparison
Crackin piece of kit
When you take it off could you get some photos of the mounting holes in the chassis?
				Re:
				Posted: Sat Mar 14, 2009 6:54 pm
				by ROC
				DanThe wrote:When you take it off could you get some photos of the mounting holes in the chassis?
Will do
				Re:
				Posted: Sat Mar 14, 2009 9:24 pm
				by dannosail
				I've got a South African E30 saloon as well except the seat belt sign is up with the check panel.  Is this a genuine BMW accessory?
				Re:
				Posted: Sat Mar 14, 2009 10:12 pm
				by Brianmoooore
				Never thought about where the seat belt warning would be on a four pot, in countries where it's compulsory!
 On six pots, it's part of the blank square (in the UK) on the LH side of the roof mounted 'check' panel.
				Re:
				Posted: Sat Mar 21, 2009 4:20 pm
				by Gwynleym10
				Re:
				Posted: Sat Mar 21, 2009 4:58 pm
				by ROC
				Nice one Gwyn, thanks for the pictures.
I thought you must have put the sports seats in.  It does not look a lot different nowadays, the BBS have gone awol and it has ended up on bottletops
, the bootlid has gained a small lip spoiler.
