early high comp engine into later sport
Posted: Thu Mar 12, 2009 1:26 am
by maz1
Will an early 2.5 engine fit into a later sport or is there additional work required.
thanks
Posted: Thu Mar 12, 2009 1:04 pm
by 327
Hi, fits ok, had this done to mine
Re:
Posted: Thu Mar 12, 2009 4:56 pm
by zinderz
Be wary of slightly different wiring looms. May cause some issues with electric windows and the like. Well that was in my experience anyway.
Re:
Posted: Thu Mar 12, 2009 5:20 pm
by zaust
You need to swap a couple bit's. (all easy) and best to have the engines side by side.
Bracket and sensor for the front pully as the gearbox one's will be redundent.
water way at the front with the cover's. and use the later injector rail on the early manifold.
You will be happy with the result fella.
Re:
Posted: Thu Mar 12, 2009 5:31 pm
by 327ire
I had lots of trouble getting the conversion to spark, turned out to be that the older engine used a different system to locate TDC top dead center. The older one used a small hole on the surface of the disk, the new one uses 'missing tooth' which is a couple of the disks teeth missing on the edge of the disk.
Much easier to do with the engine out!!!
Re:
Posted: Thu Mar 12, 2009 6:44 pm
by maz1
Thanks guys for all the info.
I will be getting it fitted by a mechanic but wanted to get all the bits I need before hand as I dont want any dramas. What actually makes the early engine higher compression...is it the head or is there a difference in the block or both.
Maz
Re:
Posted: Thu Mar 12, 2009 6:50 pm
by maz1
Also my car has Air Con, That wouldnt make any difference would it? Will their be a noticable difference in performance.
Maz
Re:
Posted: Thu Mar 12, 2009 6:52 pm
by ed325i
The pistons
Re:
Posted: Thu Mar 12, 2009 10:33 pm
by zaust
You will notice it has better torque all through the rev range..
Enjoy.
