Touring coil overs
barryj
Thu Feb 26, 2009 1:32 pm
I have already asked a question on the touring suspension and been told that the struts on all tourings are of the 51mm 325i variety.
Given that have they got this wrong states 45mm strut:
http://cgi.ebay.co.uk/SPAX-RSX-COILOVER ... 240%3A1318
And states 51mm strut:
I am not buying the Spax ones BTW, its the GAZ I am getting but just noticed this when surfing.
Building an S50 3.2 Touring.
mr_dink
Thu Feb 26, 2009 2:33 pm
Hi Barry,
I think the first listing should actually be a kit for saloons as they give production dates of 88-93.
Realoem is telling me there were no 316 tourings until 91.
Also they state except 4wd, all the 4wd models were 325s IIRC.
I would guess that the kit pictured is 51mm, the pictures are the same in both so I reckon they're just listing the same kit for different models. Don't really think they know what they're on about!
barryj
Thu Feb 26, 2009 8:51 pm
I thiny you are right, I will be ringing the guys at Gaz tomorrow.
Theo
Thu Feb 26, 2009 9:19 pm
If your 316i touring is on it's original suspension then it will definitely have 51mm struts.
Let me know what Gaz say, I need a set of coilovers with spherical bearing rear top mounts at some point - would be interested in what price they quote you.
barryj
Thu Feb 26, 2009 9:22 pm
No worries I will let you know
BadDave
Thu Feb 26, 2009 9:24 pm
Theo
IIRC a pr of Gold range,rears with springs and R/J top mounts cost me about £330 delivered late last year.
HTH
Theo
Thu Feb 26, 2009 9:26 pm
BadDave wrote:Theo
HTH
Cheers Dave, that's not too bad. Sadly I need the fronts as well :(
barryj
Thu Feb 26, 2009 9:28 pm
Thick end of £800 I am budgeting, by the time I add the brake conversion and the G-werx hub adapters I reckon the whole front/rear suspension & brake package will be about £3k 8O
Theo
Thu Feb 26, 2009 9:39 pm
Will be a good setup though Barry 8)
When you talk to Gaz, ask them if the E30zone discount that JimmyC organised is still valid.
BadDave
Thu Feb 26, 2009 10:03 pm
Ask for Dave Lyon and mention the Zone discount
When i did, it only applied to the dampers and not the springs or top mounts IIRC
Still better than nothing though
